Question about Toro Lawn Mower With Toro Power Tools
Engine started leaking oil near the back of the engine and collects on deak
    Habit-Forming:
  • 34 Answers
Hi, You need to clean the engine thoroughly with some Purple Power or Fantastic and a garden hose. Then run the engine for a short time and locate exactly where the oil is coming from on the engine. One place to pay close attention to is directly under the cylinder where the crankcase mates with the oil sump. Some engines have gaskets fail directly under the cylinder because A; there are no bolts securing the oil sump to the crankcase in that location and B; it is an area of very high heat. I am assuming this is a push mower and does not have overhead valves? If it does have OHV, keep an eye around the bottom of the valve cover. Lastly, the crankcase breather cover gasket or the rubber tube the goes from the breather to the air filter housing may have come off or it may be cracked. But first things first, you must get the engine clean to determine where the oil is coming from. After establishing the location of the leak, post back with the info and I will provide direction to make the repair.Kevin,
Kevins Small Engine service,
South Berwick ME. 03908
Posted on May 14, 2013
Engine oil level lowers with no visible oil leaks and engine not smoking
sounds like leaking through back crank-shaft seal if so will be collecting in bell-housing should be rubber grommet in this that you can remove to check
Oct 07, 2013 | 1992 Mitsubishi Pajero
I have a 99 Blazer that started leaking oil near rear of block. At that time plenty of oil pressure...I was driving to get it checked and noticed I had no oil pressure. Returned home with no problems.
The oil sneding unit is back there on top of the engine. Some times when they go bad they will leak oil threw the top/plug. This is the problem. It is about 3" long Sit in the middle of the engine all the way at the back.
Jul 02, 2011 | Chevrolet Blazer Cars & Trucks
I have a Husqavarna LT100 mower (15 years old) It started leaking oil from where the B & S engine is bolted to the frame. I've tightened up the 4 bolts but its still leaking. Any ideas...
Bear in mind that the bolts holding the motor to the frame do not have any oil passages near or through them. The oil is just oozing down the side of the motor and collecting there. If there is a little valve cover near the spark plug(s), the gaskets for these often get hard with age, leak and need replacing. This will be a small door about 2x3 inches with a bolt on the top and bottom, again near the spark plug(s). remove the bolts, take off the cover, clean the old gasket material off the cover and the engine block, put your new gasket on and snug the bolts back up. In the real world this would be a good time to have someone adjust the valve clearances too, given the age. You are not doing that yourself and when I replace that gasket I put some gasket goop on the new one before I put it in. I have a very handy neighbor who is subject to beer bribery and I have him adjust the valve clearances.
Apr 12, 2011 | Garden
Leaking oil, collects on bottom of oil pan.
You have to check that the crankcase is not broken, if in perfect condition, check thebase of the distributor usually the leaks start there.
for checkups, take the engine to be washed after a walk of about thirty minutes back andcheck carefully.
Apr 12, 2011 | 2002 Mazda Tribute
My 1995 Saturn has on oil leak-it looks to be near the right-side CV-Axle. Also it lacks power. I cleaned the sparkplugs recently and it was running fine again, but when I put about 4 quarts of oil in,...
IF OIL LEAK RED IN COLOR.TRANSAXLE AXLE OIL SEAL LEAKING.HOW MUCH OIL PUTTING IN THE ENGINE TOO MUCH OIL FOUL OUT SPARK PLUGS.YOUR CAR USE 4 QUARTS OF OIL PLUS NEW FILTER.
Mar 22, 2011 | 1995 Saturn Sl
Oil leaking from behind the motor
if the oil is leaking when the vehicle is running the rear main seal ,between the engine and transmision is leaking. if not maybe there is a oil pressure switch at the back of the engine leaking ,or the valve cover gasket is leaking near the back of the engine , have the engine steam cleaned then you will see where it is leaking ,
Nov 18, 2009 | 2001 Ford Windstar
How to change oil on 90 nissan maxima
Park the car on a level surface, let the engine warm up, Locate the engine-oil pan under the car, and remove the drain-plug. Put a container under the oil-pan to collect the old oil. Remove the oil-filler cap on top of engine head-cover. Remove the oil-filter by the engine block. You could grab it with one hand and turn counter-clockwise. While waiting all oil to drain out, smear some new engine oil on the new oil-filter 'o'-ring, and screw it back in place. Tighten 3/4 turn after the o-ring hits the engine surface.
Clean the drain-plug with a clean rag and tighten back in place-not over-tighten it!. Put back about 3-quarts of new engine oil through the oil-filler cap, and hand tighten the cap. Start the engine and look for leaks. After a few hours later, check the oil level. You are done!
Sep 26, 2009 | 1990 Nissan Maxima
With normal drive my ford expedition 2005 started collecting engine oil near the valve cover post oil change. While parked or idling, I do not see any visable smoke or leaking oil...can you help?
you prob. have spilt oil while poring it in. you can also look closly to the valve covers-whipe clean and keep checking to see if you need new gaskets.
Jun 12, 2009 | 2005 Ford Expedition
Engine oil get less every two weeks in my pajero 4m40
Diesels do lose a little oil out the blow-by tube. If the engine temp. is higher then normal then you will lose more then normal amounts. If you are not leaking it then you are burning it, Possibly worn rings, head-gasket, or oil leak inside turbo. 68 MPH and higher doesn't sound unusual, is the engine still stock?
Jun 03, 2009 | 1995 Mitsubishi Montero
Oil leak from tube
you need to replace the o ring on the oil drain dolt that should stop the leak
May 24, 2009 | 2003 Harley Davidson FLSTF Fat boy
Toro Lawn Mower With Toro Power Tools Logo
261 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
