Philips 190cw what is the usb port for?
2 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: philips 190cw writes on the screen that the keys
press the ok button and keep pressed upto 15second untill the unlocked messege will appear
Posted on Mar 30, 2010
Hello. how can i use USB device on this tv philips tv 37 inch 37pf7411/12 model.
You can't use a USB device directly with the Philips 37PF7411/12. What you can do is connect a set top box (some DVD/Blu-ray players, OTA DVRs or a computer) with a USB port to the television via one of the HDMI ports. You will need make sure that the set top box will support the file format of the file on the USB device.
Turn off both devices before connecting the video cable. With a computer, you should turn on the TV first, then set the input to that port. Then turn on the computer and use the box to send the file to the television.
You can find the documentation for the 37PF7411/12 on the product support page: http://www.p4c.philips.com/cgi-bin/cpindex.pl?scy=NL&slg=EN&ctn=37PF7411/12 . The direct link to the manual is http://download.p4c.philips.com/files/3/37pf7411_12/37pf7411_12_dfu_eng.pdf .
I hope this helps.
Jul 09, 2017 | Philips Televison & Video
The screen Won't "awake" after power off
check the data cable of your lcd try to replace the data cable it might resolve your problem.
Nov 19, 2013 | Philips 190CW
1440x900 resolution not showing up
Hi look in device manager..
You might need to be logged on as an administrator in order to do this.
Open Device Manager, click Start, and then click Control Panel. Double-click System. On the Hardware tab, click Device Manager.
See if there's a warning triangle next to your Graphics/Video driver. If that's the case, try rolling back/updating the driver. If that fails or you don't have one to roll back - look on the munufacturer's site for the correct drivers for your OS/ Graphics/Video card.
Jun 12, 2012 | Philips 190CW
190cw brightness box wont leave the creen unless i hold down a button and keep it help down?!
I had this same problem. Check if your system time is correct; as I had problems with the motherboard battery, my Windows time kept resetting, once I set the correct time it worked OK.
Nov 05, 2011 | Philips 190CW8FB LCD Monitor
My Philips monitor 190CW doesn't works in Win7 64-bits. In Win7 32-bits workss well
that's odd?
what operating system do you use?
do you check already the video configuration for your monitor?
Jul 25, 2011 | Philips 190CW
Philips 190cw writes on the screen that the keys are blocked
Mar 28, 2010 | Philips 150C4FS 15" LCD Monitor
Philips External hard drive not connecting
Try connecting it to a different usb port. plugging out without first stopping the usb device must have the device settings on that port.
Dec 05, 2009 | Computers & Internet
My laptop dosent recognize my phillips gogear SA60XX
You can get the installation software from Philips website. Some laptops have a USB 1.1 port, which does not have enough power to support an Mp3 player. If the laptop USB port is definitely a USB 2.0 port, then hold in the volume + button on the Go Gear before connecting it to the laptop to see if you can force recognition.
Nov 23, 2008 | Philips GOGEAR SA6045 MP3 Player
My LCD philips 190cw isn't work after i move it??
make sure the video cable is fully connected
Jul 02, 2008 | Computers & Internet
Vista software download
http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exe
Sergio
Todo: Check USB port
Howto:
061027085005_16154.png Refit the USB cable into the port.
061027085005_16154.png Plug the webcam into another USB port.
061027085005_16154.png Use an external powered USB-Hub. Some USB ports on computers do not have enough power to feed USB devices (this mostly occurs with laptops).
061027085005_16154.png Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
061027085005_16154.png Follow the steps to update the USB driver
Windows2000
061027085005_16154.png Click Start -> Settings -> Control Panel -> System
061027085005_16154.png At the bottom of the tree click on the + sign before Universal Serial Bus controllers
061027085005_16154.png Click on General USB Hub, right mouse click and click on Properties
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
Todo: (re)install the latest driver
HowTo:
061027085005_16154.png Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
061027085005_16154.png Cleanup the computer with for instance CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
061027085005_16154.png Download and install the latest driver.
Apr 12, 2008 | Philips SPC700NC Webcam
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
