Question about Olympus m:robe MR-500i MP3 Player
Erroe Code : 0400001F
System Error Error code : 0400001F Please push a power switch. How do I fix this error????
  • 4 more comments
  • alex heller Nov 28, 2007
    i have the same exact problem, but my m robe wont even turn on, i have no idea how to get to the hard drive or the ribbon cable. can you please help me?
    I have the same exact problem, but my m robe wont even turn on, i have no idea how to get to the hard drive or to the ribbon. can you please help me?
  • ness breezy Jan 02, 2008
    i have the same problem with mine too ive reset it like it said  an still dont work.
    can sumone in las vegas,nv 89119 fix my problem of dis error code i will pay money cash!!!!contact me on 323-506-1999 or 702-466-9236 plz....
  • Anonymous Nov 03, 2008
    system error
    error code: 0400001F
    please push a power switch
  • danilojavier Mar 28, 2009
    i have the same problem. once, I wanted to look inside the player but i removed de hard disk connector by accident, when i plug t it :
    "Erroe Code : 0400001F"
The ribbon was dislodged from the circuit board connector, I re inserted it and it worked.
Thank you
Posted on Sep 20, 2008
    Scholar:
  • 67 Answers
This error code is very hard to fix. You may end up having to send it back to Olympus or buy a new one. But here's a few things to try and you may get lucky. Connect the remote, power on the player and hold down the heart, mode and play buttons on the remote at the same time. This re-sets the player. If this doesn't work, remove the back cover. There are 4 small screws that hold the back plate on. Once the cover is removed, unplug the battery. Plug it back in after 30 seconds. The player should re-boot. You can also try disconnecting the hard drive and reconnecting it. Unplug the battery before disconnecting the hard drive. If none of these suggestions work, you may be out of luck. i know of no other ways to fix this error code.
Posted on Aug 14, 2007
The hard drive ribbon cable isn't in right. Make sure the ribbon is pushed in all the way and STRAIGHT.
Posted on Nov 03, 2007
'["65.639[-uj/8-[
Posted on Mar 26, 2008
2 Suggested Answers
SOURCE:
  • 69 Answers
SOURCE: Erroe Code : 0400001F
There is an error with the HDD (Hard Drive)
It has either malfunctioned or the interface cable has been disconnected or not connected properly.
If the HDD still spins (listen for the spinup) then it has either malfunctioned or cable has not been connected properly.
Posted on Oct 07, 2008
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Erroe Code 0146 (Dell Inspiron E1505) MSD Unit 0 DST Log contains previous error. ???
Hi ! Error code is this error code 2000 - 0146??? if that is the error message you have to contact dell technical support to replace the hard drive because that error code mean that the hard drive is already faulty. You can Reinstall the Hard drive as well but it is not guarantee that it will fix the issue. Most of the time dell will send a hard drive replacement for that kind of message if the system is still in warranty it will be free but if not you have to pay for the replacement. Hope this will help you . God Bless!
Apr 18, 2011 | Dell Inspiron E1505 Notebook
Hello my name is yogesh my leptop model is studio1555 and the problem is how to remove hdd password on my leptop because i set password but this password are not work and after 3 times you rong password...
you'll need to contact Dell support for this one. they will be able to help you request a password that you can use to reset/clear the hard drive password. After it is reset, you may then set a new hard drive password if preferred. Be sure that you have the ownership information of the system in order to get help from Dell about this issue.
Aug 31, 2010 | Dell Studio 1737 Laptop
Erroe message on screen "system error contact xbox support
Is there an error code on the bottom of the screen?
E73?
E74?
E68?
E69?
Or another code?
May 28, 2010 | Microsoft Xbox Console
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two
installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the
EIO card.
n If this Error Code disappeared after removing the Hard Disk
Drive, then switch the Printer OFF and reinstall the Hard Disk
Drive, making sure that the two installation screws are
completely tightened. Switch the Printer ON again. If this Error
Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
n If this system error continues to appear after replacing the EIO
card or the Hard Disk Drive, then replace the Electronics Module
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
Oct 05, 2008 | Olympus m:robe MR-500i MP3 Player
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Christopher
Jul 15, 2008 | Canon NP 6545 Copier
Error code : 0400001f
fatal system error
service required/004
Nov 26, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe MR-500i MP3 Player Logo
656 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
