Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Runs fine than it acts like it's out of gas but if I move the lever from forward to neutral it gets going again
I changed oil, filter, fuel filter, plugs,fuel punp,and it will run fine for awhile. Everything seems normal than the engine will sound like it is running out of gas or what the motor sounds like if you raise up from the seat. If I put the lever from forward to neutral the engine will come back to lfe again. I thought I could smell gas when it did. What the heck is going on?
  • 376 Answers
SOURCE: I have gas going into my oil. 17.5 Briggs solenoid on carb bowl
The problem is the float needle and seat are leaking. It is not shutting off the gas when the bowl is full. The bowl fills up, then runs down the intake through the intake valve into cylinder, past the rings into the crankcase. Fairly common problem. Just replacing the rubber tipped needle probably will not stop the leak. The pressed-in brass seat needs to be pulled out and a new one pressed in also. Possibly there is some trash or rust in the carb that has gotten between the needle and seat, but in my experience, it usually takes replacing both to fix.
Posted on Jun 25, 2009
  • 130 Answers
SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Posted on Jul 18, 2009
SOURCE: My Poulan 42-Inch 17.5 hp Briggs and Stratton
OK, so I had the same problem. Would not go into gear forward or in reverse. I took it apart and nothing seemed out of place or broken. I scratched my head for an hour... asked my wife if she had done anything to the machine while I was gone and she replied I only had a tire fixed!!! Bing bulb went off.... She had removed the tire from the shaft and had lost the SQUARE KEY for the drive shaft, one 20 cent square key for the drive shaft and it worked!! TA DAHHH!!
Simple fixes for simple problems.
Posted on Jul 20, 2010
  • 4 Answers
SOURCE: My 97 poulan lawn tractor runs strong for a few
It sounds like you have some debris or water in the carberator. You can drain the bowl easily depending on the style of carb. Most newer units take a 7/16 or 1/2 inch opened end wrench and just loosen the bowl bolt or valve whichever it might be until you get fuel or fluid flow. If there is water or other debris I recommend dumping the tank and flushing the fuel system with a good carb cleaner.
Posted on Nov 08, 2011
bc877
SOURCE: My 97 Poulan lawn tractor starts and runs for a
Had the same thing, clean the hole on the gas cap.
Posted on Sep 09, 2012
My club car gas golf cart was running good then al the sudden wont go over idle speed
Perhaps it's a stuck carburetor float valve, bad fuel pump (if it has one) or clogged fuel filter.
Jul 03, 2015 | Cars & Trucks
My 94 full size blazer starts and idles fine in park and in neutral. When I put the truck in gear and hit the gas, it'll start, then act like it wants to die. The Catalytic converter is off, I'
yes try getting the fuel pump pressure tested by a mechanic. the other thing it can be is the injectors are plugged try running some lucas fuel system cleaner.
Jan 19, 2013 | Chevrolet 1500 Cars & Trucks
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
450 Case Dozer - Changed Transmission Fluid - Now Will Not Move ?
Make sure everything is in neutral. Hi-Lo lever on floor is in Lo range. recheck trans fluid level under the seat. Let idle for 2-3 minutes. Put steering levers in low, ebrake off, then put in forward or reverse. Tracks should 'jump' and you should be off. The brake lines can put pressure on the slave cyl that force the spool valves into neutral. I would suspect that is the issue. The two slave cyl located on the brakes themselves must NOT be activated, so make sure the plunger is all the way down on them.
Apr 02, 2012 | Cars & Trucks
1997 nisssan pickup 4 cyl. 5 speed. Truck runs fine at all speeds until the engine gets really hot (outside temp 100+ degrees), then engine sputters and will not take gas. Acts like old cars that had...
There may be more specific solutions along shortly, but my older car had similar problems until I changed the ignition module. The "spark box" as it was nicknamed. My car was a mustang, but it only seemed to act up on hot days, and if I just pulled over and allowed the car to cool for a bit it would go again just fine. I'm not familiar with Nissan trucks specifically, but it's another place to consider. Good luck!
Aug 14, 2011 | 1997 Nissan Pickup
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
2000 1500 Sierra will not stay running step on gas act like its running out of gas. Popped top fuel line gas came poured outbut didn't pump out when i rolled the engine over. Got underneath the fuel cell...
Replace the fuel pump and fuel filter to correct the problem you are having. Without the proper fuel pressure the engine will not run at all. Hope this will help you. You might check the fuse/relay panel for a blown fuse or relay in it to make sure you are getting power to fuel pump before you go to the trouble of removing the pump and fuel filter. Hope this will help you.
May 20, 2010 | Cars & Trucks
1991 Caprice No reverse. Moves in neutral. All forward gears OK.
shift linkage needs adjusting,,could be bent, easy fix, located along firewall to fram beneath the column, ask your son wut he ran over and didnt tell u about... hope i could help...:)
Mar 22, 2009 | 1991 Chevrolet Caprice
What engine? Rear wheel drive ?Sounds like shift linkage or cable out of adjustment slightly. Have a look at where cable or rod attaches to transmission for adjustment. If not sure of what your looking for get back to me with info.
Mar 21, 2009 | 1993 Nissan Maxima
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
56 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
