Question about Maytag HAV2558 Top Load Washer
I need help fixing it! What is wrong...
My machine was out of balance...I was doing a load and the there was a bad noise, then smoke was coming from the tank when I lifted the lid. I figured it was a belt since there was definitely a rubber smell-when the machine was opened, the belt was burnt on the gear-so I got a new belt. Then nothing would happen, so I thought it was the water pump. I put in a new water pump-first run through and the washer worked. I did a dance, but my joy was short- lived. The machine does not seem to agitate well, and now it won't drain-there is water in the tub. It fills, but does not drain...I tried to drain it again, but it won't, and I think I smell that old familiar rubber smell...could it be the plastic gear that the belt runs around? The belt seemed loose and the plate did not move easily. I hope it is not the transmission since a new part costs 269. I have already invested 68 for the pump and 28 for the belt-please help!
  • 18 Answers
SOURCE: Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Posted on Feb 04, 2007
hotuna
  • 288 Answers
SOURCE: plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Posted on Mar 15, 2008
JR JR
  • 116 Answers
SOURCE: Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Posted on Nov 30, 2008
Healeyman
  • 1198 Answers
SOURCE: washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
Posted on May 04, 2009
JULIANFIX
  • 975 Answers
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Posted on May 18, 2009
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
I have WSXH208A front loader. Recently it started making considerable noise during the spin cycle. It spins uniformly so it is not a balance problem. When I spin the drum by hand it spins very rough,...
it is not a easy fix,, the whole tub has to come out and then apart,, i would recommend getting help with this, there is to much that can leak and go wrong
Jan 23, 2011 | GE WSXH208A Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Knocking noise coming from belt area. when belt
Had the same issue and it turned out to be the balancer. Not too difficult to fix any questions or advice, I am happy to help you. Justlet me know. Good luck
Jul 11, 2009 | 1992 Buick Century
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag HAV2558 Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
