Question about Motorola Walkie Talkie 2-Way Radio
Fcc id k7gmjbgj
How to get walkie talkie to stop going to sleep mode
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
eradiostore
  • 1654 Answers
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
I need instructions on a Motorola walkie talkie FCCID K7GSX900
Go to the following web page and download the manual: http://www.manualdisk.com/pdf-/motorola-walkie-talkie-fcc-id-k7gsx900-range/
Mar 04, 2015 | Motorola Radio Communications
WHERE CAN I BUY ONE
Check ebay, search TalkAbout T8500.
Best regards.
Oct 16, 2014 | Motorola Walkie Talkie 2-Way Radio
Fcc id k7gmhbcj
Most replacement batteries for the TalkAbout line of radios can be found at http://wirelesspro.com/
Best regards
Jul 16, 2014 | Motorola Walkie Talkie 2-Way Radio
Fcc id k7gmhbcj
Be sure the "Channel" and "Code" settings are identical on both radios.
Apr 18, 2014 | Motorola Radio Communications
NOT WORKING 2 WAYS ONE SET SEND AND RECIVE ANOTHER ONE ONLY RECIEVE MOTOROLA WALKIE TALKIE fcc id k7GSX900 UPDATE
Check your programming. It is possible one of them has a different PL (aka code or interference eliminator code) than the others. Here is a link to the user guide page where you can select your model from the pulldown. http://shop.giantintl.com/Manuals.asp Look at the section about programming and turn off any special features, taking your radio back to a very basic mode, matching all setting between the radios. This should make your radios communication easily together. If not, you may have one bad radio in the mix.
Best regards.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
Can i connect an antenna, lets say 200ft in the air to motorola FCC ID:K7GMJBGJ
It is Possible, but not recommended.
By the way when you post a query, always Give the following info:
Make & Model of your radio
Giving the FCC ID is of no value here.
Cheers,
Peter
Jan 07, 2013 | Radio Communications
I got a Cobra cxt275 for Christmas and i can't get the maximum range i can't get 4 miles with it is there a way to change it that i can get 20 miles like it says in the owners manual
Yes you can. If youre using it on certain channels (using the FRS frequencies) you will only get about 4 miles. FRS stands for "Family Radio Service". If you use the GMRS frequencies it will broadcast at higher watts (verses lower watts on FRS). GMRS stands for "General Mobile Radio Service" which you need a license to broadcast over. frequencies for both can be found here: http://gmrsfrequencies.com/gmrs-frequencies-chart.html
However to go on the channels that use GMRS you need a FCC call sign or ID license. you must call out your ID number every 15 minutes to be allowed to broadcast any sort of transmission or you can be fined or jailed (so they say). People sometimes dont obey those rules and the FCC will sometimes geo locate your transmissions and pin point your exact location. A 1st offense can be light to severe depending on what you're doing (pirating radio, blabbing, misusing the channels, using it without a license, using too many call tones, abuse, etc.)
Im guessing you might not understand this in the first place. when you buy radio walkie talkies, they all say inside the manual that you need a FCC license to operate it on GMRS mode, IF its GMRS compatible which today most walkie talkies are. a set of channels is designated for GMRS use and regular use of a walkie talkie has a set of channels it uses for your goofing around or just experimenting.
hope this helps.
-jacob ray
Dec 26, 2010 | Cobra Two Way Radio
Radio Communications Logo
136 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
