Question about Sony BRAVIA KDL-32V2000 32 in. LCD Television
Kdl-32v2000 sony bravia .The tv works 20 sec's end stops for 10 sec's 9 flashes
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: I own a Sony Bravia KDL-32V2000 and whenever I
I take it that you mean that you were previously watching AV4 and then you switch off, then when you switch back on the next time its reverted back to default TV source.
If this is correct, then try this first: switch on, then menu and change a setting in the picture submenu, it doesn't matter what you change just as long you remember what you change>now switch it off and wait 1 min>now power it back on and check the setting that you changed is still set.
If the menu change has gone back to before you changed it means that your TV is in "Shop Mode": When its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
To sort this I would you should "Restore Default" settings and set the TV as "Home Mode" and not "Shop Mode".
If it was not in "Shop Mode" I would still do the above.
If this doesn't sort it out, I will get 32V series on my desk in work and try and replicate the problem your having, I will let you know.
Thanks
Posted on Sep 09, 2009
  • 65 Answers
SOURCE: kdl-32v2000 sony bravia self diagnostic 4 flashes
Sounds like bad inverter boards.
Posted on Mar 22, 2010
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony Bravia stopped
press the power button once and then look for a flashing light that will give you some kind of indication of what your problem is the light should tell you a short code such as it will flash threee times then once or 2 times then 3 then 1 or sumthing along thos lines then you must refer to you owners manual and look under the troubleshooting for info on you problem
hope this helps :)
Oct 20, 2012 | Sony BRAVIA KDL-32V2000 32 in. LCD...
How do I tune in channels on this TV
if you hook to cable. first you need to go program ang scan the autoscan first in order to change the channel.
May 09, 2010 | Sony BRAVIA KDL-32V2000 32 in. LCD...
Sony Bravia KDL-32V2000 LCD TV switching off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 29, 2017 | Sony Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-32V2000 32 in. LCD Television Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
