Question about Xerox WorkCentre 7120/P Printer
Error 10-338 this error code is on UI
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
How to connect samsung smart tv and netflix with ui-113 error code
I have the same issues, I tried everything from disconnecting the modem to resetting the TVs smart Hub, I also tried all Netflix recommendations and I am still having the same problems, please help if you have a solution
May 25, 2014 | Computers & Internet
Unable to login
You need to reinstall the software.
Oct 07, 2012 | Individual Software Typing Instructor...
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
- If both are replaced the problem has been repaired.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
manager.
EEPROM VERSIONS.
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
1 minute.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
No communication between UI and CCU
Hi.
I think that by this time you already fixed the problem. The codes indicate usually a fault that is either CCU or MCU.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Oct 19, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
Xerox WorkCentre 7120/P Printer Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
