Question about Toro Garden
Model lv195ea starts and runs but does not speed up under load
    Master:
  • 969 Answers
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
Posted on May 24, 2014
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Jul 03, 2014 | Ingersoll Rand Electrical Supplies
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
My generator only puts out 89 volts.
I need a model number for your ENGINE not the whole generator. I believe this is a case of the engine not running fast enough. I.e governor adjustment will be necessary. Respond with an Engine model number and I will stll you how to adjust the governor speed.
This is GENERIC but the Governor arm has a spring that connects to a speed plate. The speed plate has a stand off screw and nut used for speed adjustment and a center nut for securing the speed plate in a fixed position. The Steps are to slightly loosen the center nut and the locking nut on the speed adjustment screw. Start the unit with a meter reading output power voltage (use extension wire for meter) Then turn the speed increase screw in to increase speed. When you reach 122-123 VAC stop. The reason you adjust it to 122-123 VAC is because voltage will drop as the generator provides power loads
Tighten the screw lock nut while running if possible and tighten the center nut on the speed plate to secure it in place. Check voltage again.
If you generator is running at normal speed and you have low voltage output... most of the time the Capacitor is failing. If the capacitor is failing the magnetic field in the armature and stator collapse under above average loads causing HUGE voltage swings.
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Briggs & Stratton Electrical Supplies
1999 3L S Type Jaguar Rough Running
WITH MOTOR RUNNING REMOVE ONE PLUG LEAD AT A TIME (INSULATED PILERS) MOTOR SHOULD REACT IF GOOD , IF ENGINE SPEED DOES NOT DROP ITS A FAULT AT THAT CLY, TRY NEW SPARK PLUG 1ST THEN LEAD, ALSO CHECK FOR ANY FAULTS OR SHORTING OF THE PLUG LEADS, COIL PACKS. (MORE NOTACABLE IN DAMP CONDITIONS) THESE CARS NEED TOP QUALITY PLUGS, OR THEY WILL ALL FAIL UNDER LOAD,
Dec 05, 2009 | 2000 Jaguar S-Type
Starts but quits under load
If it won't pull under load it usually means it's sucking air somewhere. Let it idle and spray around the intake with wd-40 untill you find the leak ( the engine will speed up when you do ) .
Sep 26, 2009 | 2006 TN'G Baja 150
2000 v6 5 spd nissan xterra idles high when in gear and rolling .
From the service manual:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
NGEC0549
PREPARATION
NGEC0549S01
1) Make sure that the following parts are in good order.
I Battery
I Ignition system
I Engine oil and coolant levels
I Fuses
I ECM harness connector
I Vacuum hoses
I Air intake system
(Oil filler cap, oil level gauge, etc.)
I Fuel pressure
I Engine compression
I EGR valve operation (If so equipped)
I Throttle valve
I Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
SEF976U
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
SEF977U
4. Perform diagnostic test mode II (Self-diagnostic results). Refer to EC-644.
SEF217U
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
BASIC SERVICE PROCEDURE VG33E
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment (Cont’d)
EC-616
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
SEF978U
3. Turn off engine and disconnect throttle position sensor harness connector.
SEF975R
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
SEF371S
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
GI
MA
EM
LC
FE
CL
MT
AT
TF
PD
AX
SU
BR
ST
RS
BT
HA
SC
EL
IDX
EC-617
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
SEF972R
' GO TO 2.
4 CHECK BASE IDLE SPEED
With CONSULT-II
1. Read idle speed in “DATA MONITOR” mode with CONSULT-II.
PEF356V
700±50 rpm (in “P” or “N” position)
Without CONSULT-II
1. Check idle speed.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
Mar 25, 2009 | 2000 Nissan Xterra
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
