Disc ejection I bought a Technics mini disc player recorder from eBay, but it won't take the discs, just ejects them. How do I fix this?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
You fix it by returning it to the guy who bought it and getting your money back. Call eBay customer service.
If it is too late, tell me more. Does the disc go right in and then right out? Does it try to read it first?
Posted on Jun 19, 2013
  • 1153 Answers
SOURCE: Techics Mini Disc Player SJ-HDA710
You may have to clean the eye or lense in order to read the disc.
Posted on Sep 21, 2007
SOURCE: Technics SJ-HD501 Minidisc Player Will not accept Disc
hello
Posted on Oct 07, 2008
  • 4234 Answers
SOURCE: stuck disc
The carriage assemblies for these units are known to break. Please DO NOT attempt to remove the disk. Bring this to an authorized Sony service center. They should be able to give you a fixed price repair quote. This is the only way to save the disc and prevent further damage to the assembly. The replacement assemblies are a bit better than the originals so you shoudn't have this problem again.
I have repaired a number of these with much success. Care must be taken so that the disc heads are not damaged.
Keep us posted.
Dan
Posted on Jun 01, 2009
SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Posted on Jun 22, 2009
SOURCE: md4 recorder mini disc. will only power up error 04
I have also the same problem with my MD8 recorder, the same error code: ERROR 04... From the yamaha website it says,
Error 04: The magnetic head didn't raise off of the disk.
Posted on Mar 25, 2010
The recorder will not eject disc.I have taken it to various places and have been told parts are no longer available. Can the recorder be repaired?
You're best bet is to find an identical one on eBay with a working disc carrier, then you can take the best of the two to get one working unit.
Mar 10, 2015 | Sony Vintage Mds-101 Compact Chassis Mini...
How do I fix my Sony MDX-D40 mini disc/cd player recorder? The mini disc won't eject.
If it's a motor issue, you're going to have to take it on. If it's just stuck, WD40, using the red tube to direct the spray as close to the hinge
Try google and you tube.
If those don't help, I'm sorry. It may be cheaper to buy a new one, selling yours on craigslist for parts.
Jan 02, 2015 | Sony Televison & Video
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Toc not writing
I was going to note that when you first turn the MD recorder on is when it will write the TOC for the disc - so even if you turn it on and press eject, it is smart enough to write a TOC first, then eject the disc. Good find on the battery loss.
Sep 02, 2013 | Sony MDS-JE520 Mini Disc Player
Dvd won't eject
Someone is going to have to open the unit to see if something is jammed in the mechanism---a disc or something out of position.
Sometimes a gentle nudge will restore operation.
Jun 10, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disc won't eject
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it.
Joe Don
May 25, 2012 | Toshiba XDE500 Player
Mini disc will not eject
Take the lid off, and save the screws!
Apr 06, 2012 | Audio Players & Recorders
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
UPON EJECTING THE DISC FROM MY MDS-JE440 IT IS WIPING ALL DATA AND BLANKING OUT THE DISC COMPLETELY ! IT HAS ONLY STARTED DOINING THIS IN THE LAST DAY OR TWO AND I'VE LOST MUSIC OFF 6 DISCS COMPLETELY, SO...
I think your recording head failed, you should stop using the deck and get a similar used one which works, repairs are usualy not cost effective.
Prodigital in Philadelphia does repairs, I paid about $250 for a replacement loader unit installed + shipping.
Feb 09, 2011 | Sony MDS-JE480 Mini Disc Player
132 people viewed this question
 Grubhead
Grubhead
