Home | GE | Security Simon 3 Wireless Home Security Sys... | Wireless failures, doo...
GE Security Simon 3 Wireless Home Security System
Problem for GE Security Simon 3 Wireless Home Security System
Wireless failures, doors that don't work consistent
By scottsill on Mar 17, 2009
I have wireless sensors that fail. Some are within 10 feet line of sight. If I bring the transmitter close to the simon it starts to work, the battery is fine in fact I have replaced the sensor and the new one does the same thing. The other interesting problem was the garage door opener is doing the same problem wont work past 10 feet. I have also replaced the panel and the new one does the same thing. There is only one wireless device in the house and that is a 6.0 cordless phone. I powered down the phone and the problem persists. Any ideas??
Comments:
Mar 17, 2009
- There are only supervisory signals at the central station, and onsite the panel does nothing when i open a door or window unless i bring the transmitter within 5 feet of the simon. There are no towers or power lines running near the home. The 6.0 phone works fine. The garage door opener works the same, within 5 feet of the reciever it works fine. This started about 2 months ago and has progressed to be as bad as it is now. The system was installed previous with a simon 2 for 5 years no problems. This problem is bad, i feel i may want to investigate with the fcc to see if anyone in the area has started a new transmitter on a tower or applied for a license in my area but other than that i still need a security system. I am frustrated to not know what changed. It must be something in the enviroment.
Clarification Request
Posted by joboo1 on Mar 18, 2009
Dude, I am totally intrigued with this! I designed communications systems for years and this is a new one on me. Your system should operate on 315 Mhz if you are in the US. But not your garage door. The supervisory signals are on a subcarrier and would normally be disrupted with the main signal. Could be a harmonic but i don't think so. Check the jam detect on the simon in all three modes and see what you get. try it on the battery only and see what you get. do you have a keyfob? what is it's range? My best guess at this point would be a new digital tv transponder that doesn't have a splatter shield or one that is not working. I'll stay with you on this, let me know!
Posted by joboo1 on Mar 17, 2009
Hmmmmmm, Interesting, what error codes do you get? Is it showing not detected or is it a supervisory communications error? Do you have overhead power lines outside? Does your garage door do funky things? How is the range on your 6.0? Lots of investigating to do here!
Solution #1
posted on Sep 09, 2009
Not Rated)
Tis_himslf
Rank: Master
Rating: 92%, 6 votes
Hi, sorry have to ask no invisible fence for dog or wireless internet? Has to be environment 2 panels doing same thing not likely. Ham radio, share wall with neighbor. Could be high emf (electro magnetic field) from electical pipe(s) in wall behind panel. May need to move panel.
Was this helpful?
Yes
No
Solution #2
posted on Jun 20, 2009
Not Rated)
rioderojo
Rank: Master
Rating: 75%, 1 votes
You probably have a few different alarm transmitters throughout your home. Perhaps one of them is a "run-away transmitter". I would take the batteries out of all transmitters and just work with one at a time -'till they are all reinstalled with out problem.Including garage door transmitter. good luck.
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
Questions and Unsolved Problems for GE Security Simon 3 Wireless
Do you recommend GE Security Simon 3 Wireless Home Security System?
Answer
Answer
how do you replace the battery for the vista 15pmt system. I have the low battery light
Answer
motion sensor wasn't working, replaced battery. Now says sensor tampered. How do I reset
Answer
i put a new back door on the house put the sencor back the same way but the alarm says bach door... (More)
Answer
our system keeps repeating module ok how can we make it stop?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Security Simon 3 Wireless...:
Top Security System and... Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Security System and... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
