Error"central directory not found"
When i try to unzip *.inf folder i get error"central directory not found". pls let me know what should i do now
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
You need to re download the file because the one you have is crroupt
Posted on May 30, 2013
Sir, i need cq50-21us windows xp pro sp2 driver path
Try the following drivers,
XP Drivers for CQ50-210US
NVidia Chipset,(install and reboot before other drivers), here
NVIDIA GeForce 8200
Nvidia ForceWare X 179.28 for Windows XP/2K 32bit, here
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
or you may try other versions, joint their forum for further details
Note:
If you found errors (hopefully it has been fixed) when installing Nvidia 8200M G video driver, you need to force install the driver.
Pieter's INF forgot to put hardware ID for 8200M G, see this post.
MS-UAA (required with a reboot before Audio, Modem and nForce HDMI Audio drivers), here
Conexant SmartAudio 221 (fix microphone problem by forum user) here
How to install:
Unzip to a folder.run installer.
if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect, Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver, here
nForce HDMI Audio Driver, here
.Net Framework(required before Intel Wireless and HP Quick Launch Buttons), here
HP Quick Lauch Buttons, here
If you had Intel PRO/Wireless Driver, here
If you had Atheros Wireless driver, here
or if it does not work try here
If you had Broadcom Wireless, here
Realtek usb 2.0 Card reader, here
Synaptics Touchpad Driver, here
If you had Bluetooth, here
If you had for 7 unknown devices (buttons drivers), here
Installation --> right click machine.inf, choose install.
Good luck
Oct 01, 2010 | HP Compaq Presario CQ50-210US Notebook
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
My lg view is stuck on a blue screen with a code showing....error fatal file dog ui. what do i do can it be fixed?
that is called the "LG blue screen of death"
you will have to restore it to factory settings.
follow the steps below:
1. Download the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directory with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
Oct 08, 2009 | LG Cell Phones
An error occcurred during the installtion of my HP 7280 photosmart printer. The parameter in incorrect.
Microsoft Windows 2000 and XP require files named printupg.inf and printupg.PNF to be found in the Windows .inf folder. If these files are missing or damaged, no printer can be installed and the error of incorrect parameter will come, and the existing files need to be removed if present, and a fresh copy of printupg.inf restored from the Windows backup archive. Kindly Do the following steps:--------
  • Double-click My Computer on the first screen or in Start menu.
  • On the Menu bar, click Tools , then Folder Options
  • Click the View tab.
  • Under Hidden Files And Folders, select Show hidden files and folders
  • Deselect Hide extensions for known file types and Hide protected operating system files .
  • After the above steps, you will be sure that the Computer is showing all files. After it >..............
  • Close the other applications. Double-click the hard drive icon that Windows is installed in, the name usually ends with C: .
  • Double-click the Windows or WINNT folder icon.
  • Double-click the .inf folder icon
  • On the Menu bar, click View , then Details .
  • Click the word Name above the list of folder and file icons until the list is in alphabetical order.
  • Scroll down the list to the section where files starting with the word print are located.
  • If files are found named printupg.inf or printupg.PNF , rename them using the following procedure:----
  1. Right-click on one of the files, then click Rename
  2. Click at the right edge of the file name to remove the highlight from the name.
  3. Press the Backspace key on the keyboard three times to remove the inf or PNF letters
  4. Type the reverse of the three letters, then press the Enter key on the keyboard. For example, inf would be replaced with fni, and PNF would be replaced by FNP.
  5. If the other file is present, Repeat Steps as through in step 4.
  • Insert a new copy of printupg.inf into the inf folder using the following procedure:
  1. Determine where the correct i386 folder is by double-clicking My Computer on the first screen or in the Start menu, then double-clicking the icon that ends with C: If the i386 folder is not displayed, click the Up or Back arrow at the top of the window, then try any other icons that look exactly like the one already tried, one at a time. If the i386 folder is still not found, insert the Windows or computer manufacturer recovery CD-ROM disc and double-click each icon that looks like a CD-ROM disc one at a time.
  2. Make a note of the path where the folder is found, including the drive letter at the end of the icon name. If folder icons were double-clicked during the search, do not use the i386 folder found after double-clicking the Driver Cache folder. For example, if the i386 folder was found on the recovery CD-ROM disc in drive G: , in folder Archive, the path would beG:\Archive\i386. If the folder was found in the computer's hard drive, the path will probably be C:\i386 . If it was found on the Windows CD-ROM disc inserted in the drive icon ending in M: , the path would be M:\i386
  3. Click Start , then Run
  4. In the Run box, type CMD , then click OK
  5. At the blinking cursor in the black box, type the following statement, where PATH is the actual path determined in step a above and _ is the underscore key, which requires holding the Shift key while pressing the Dash key: EXPAND PATH\printupg.in_ C:\XXX\inf\printupg.inf .
  6. The text that Windows displays in the black box will now indicate if the file was found and expanded or not. If the text includes an error message, type the statement above again at the blinking cursor, checking for accuracy. Ensure that all backslashes and the single blank spacebar key after the underscore (Shift+Dash) are included, and that a full colon is typed after each drive letter.
  7. If another error is displayed, verify that the PATH being typed is correct by referring to step a above, then type the statement again
After the file has been successfully expanded, close the black box. The missing printupg.PNF file will be created by Windows when it is needed.
  • Uninstall and reinstall the printer software by using the procedure recommended in the documentation that came with the printer.
Thank you, Have a nice day.
Sep 28, 2009 | HP Photosmart C7180 All-In-One InkJet...
Audio driver
Compaq doesn't provide XP support for this model. Fortunately for you someone has done a lot of work to find drivers that will work.
NVIDIA GeForce 8200
Note:
How to install:
Reboot.
Good luck
The Vista Drivers are HERE
If you need any more help just let me know.
Please don't forget to rate my solution, FixYa
Thanks!
Mar 01, 2009 | HP Compaq Presario CQ50-210US Notebook
It says application has failed to start because saAuditMD.dll was
Fix: Please download the file from here and place in the following folder: C:Program FilesSports InteractiveFootball Manager 2009
http://downloads.sigames.com/download/saAuditMD.zip
Dec 30, 2008 | Microsoft Windows XP Professional With...
Finedrive 400 Error
write me at vince954@yahoo.com if this does not work. There is a zipped version of the map_sd folder on the disk also just in case the main unzipped copy has any issues. to use it, copy the directory to your pc, unzip it and then copy the contents to your sd card.
Aug 17, 2008 | Fine Digital FineDrive 400 GPS Receiver
No sound
Pls check you computer's device manager by ff the steps below.
for winXP:
Start > control panel {classic view} > systems> hardware> device manager. PLs check if theres any yellow exclamation / question marks on your sound device. If theres any go to this website to download your sound driver at http://www.mediafire.com/?dg0cmmkm4y4
{also check on your device manager if it is disables { red X }, if so right click it and choose Enable. }
On the link i provided above pls ff the steps below onhow to install it.
Use this for audio.Unzip to a folder.Run installer.If it errors use Device Manager.
No to connect,
Reboot.
Pls let us know as soon as you followed the steps above.
Good Luck .
Jun 11, 2008 | Computers & Internet
Iexlporer probleme
Try finding Netconn.exe in your C:\Windows directory and double-clicking it. If the error still occurs, delete Netconn.exe, and then click Start, click Run, type MSCONFIG (hit enter), click the Extract File button, type in NETCONN.EXE as the file you would like to extract, click the button labeled ‘Start’, type the path to your WinME installation files where it says ‘Restore From’ (example: D:\Win9x), and type in ‘C: \Windows’ where it says ‘Save File In’ and click OK.
Naturally, back up registry, move copy of deleted keys to desktop before removing.
Delete HKEY_LOCAL_MACHINE,System, CurrentControlSet, Services,
ICSharing (the whole thing).
In addition to removing the whole ICS Sharing folder,
HKLM\System\CurrentControlSet\Services\ICSharing (entire folder),
Remove HKLM\System\CCS\Services\RemoteAccess\LocalNameResolution (all keys)
Extract ics.inf, icshare.inf and icsharep.inf to a temp folder (like C:\ICS)
May 10, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
