Question about RaidMax (ATX-612WBP) ATX Mid-Tower Case
Similar "No Power" problem
I tried the solutions suggested in the other problem like this, and put in the washers for the scews (I did take time to feel ashamed of myself for forgetting that) and checked for any other contact, and there was none. So I hit the buttion, thinking it would work and got squat. Any suggestions anyone?
  • 196 Answers
You're not giving us enough to go on. "The other problem like this" is not listed here, so we can't refer to it. Is the power button connected properly? One way to check is to remove the board completely, connect the power supply and short the power pins. This will tell you if the board and power supply are working.
Posted on Aug 12, 2007
SOURCE:
I have a frigidaire FRFW model washer that keeps beeping when it's plugged in. All the lights along the right side blink 9 times and then pause then 9 times then pause. Washer won't run.
I just had the same E90 code with my "good model" Frigidaire washer. It beeps 9 times, then pauses and repeats. Nothing worked as far as resetting, unplugging,etc. HOWEVER, I saw this guy's video and his "hairdryer technique" worked perfectly.
https://youtu.be/IhHvw2K7XO0
I took it a step further by not only removing the two screws from the back of washer and the top cover, but also removing the front panel w/buttons by taking off two scews in front top corners and three scews inside the detergent drawer (take drawer out first). I moved the hairdryer back and forth over all the wire harnesses for about a minute, plugged it back in and it beeped once like normal. Put it all back together and it's running a load of wash now!! Good luck.
May 23, 2018 | Frigidaire Washing Machines
Loose Boot spring
any answer is better then no answer at all. Try to scew it back in. if that dont work you can replace the boots or take the rest of them off.
Dec 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Remove gasket from front loader
disconnect from power
take top of machine look down at gasket thre is a eire clamp locate the screw in the wire and un scew till wire loose enough to come of then remove gasket if srew underneath put top back on and tip machine on one side carefully and look for screw
the wire is just a very large hose clamp
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Washing machine will agitate but won't spin out water
Good Morning Friend,
I understand that your Frigidaire washer, model# ATF6000ES, is agitating but not spinning the water out of your clothes. I suggest trying the following solutions:
    1) Make sure you select the appropriate spin speed for the load.
    2) Make sure you do not overload washer.
    3) Make sure the load is not too small. Add 1 or 2 similar items to help balance the load.
    4) Make sure the load is not out of balance. Rearrange load to allow proper spinning.
    5) Make sure that the drain hose is not kinked. Straighten drain hose.
    After checking the above, reset your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Hinges broken while opening
i have fixed one by replacing the scews on each side my kids like to carry it around by the screen , you may have to put a small washer to hold the screw from going in to far try it good luck don
Nov 02, 2012 | Acer TravelMate 4740
I cannot remove the push pins in the wheel weel on my Mazda CX7. Any suggestions? They have a philips screw head but unscrewing does nothing.
TRY TO PRY WITH A FLAT SCREWDRIVER BETWEEN THE SCEW AND WASHER DURING YOU UNSCREW THE PHILLIPS ...IT SHOULD BE OK....
Dec 04, 2010 | 2007 Mazda CX-7 Grand Touring
We have a v illeroy and bch cistern that cracked
yes i can,,,he done the scews up to tight that hold then down and the move ment in them is cracking the screw holes out, undo the screws a little that hold them down and maybe put in some rubber washers as well,,,you only sit on them, its not a jig your doing
so they realy dont need to be done down tight only just to hold them thats all,
Jan 12, 2010 | Villeroy & Boch 6610 11 Subway...
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
F30 ERROR CODE
your dispenser motor arm is out of position. take the scews out of the back of the units top and remove top and you will see the dispenser arm out of position.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung rs2578sh
Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Open Questions:
SBCglobal MAil SuPPoRt {1-/855/*536/*5666/}#[email protected] NuMbER HELP This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
See all RaidMax (ATX-612WBP) ATX Mid-Tower Case Questions
RaidMax (ATX-612WBP) ATX Mid-Tower Case Logo
Top RaidMax Computers & Internet Experts
Marvin
Marvin
gaucherre
Tom Chichester
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
