Question about Saws
Motor wont start
When I plug in my saw the motor just hums
Assuming the motor shaft is not frozen and the rotor turns freely by hand
All single phase induction (No brushes) motors require energizing a "starting" winding for a second or so to get the thing turning.
Once the armature in turning the "run" windings take over and the start winding is turned off. If power is left on more than a few seconds without the motor starting, the starting winding will be permanently damaged. It can tolerate power for only a few seconds.
The momentary connection to the start circuit is controlled by any of several different methods. The most common system is a switch located at the opposite end of the motor from the output shaft. The switch is in the end cap and there is a flyweight on the armature that opens the switch when the motor gets up to speed. If the switch fails to make contact when stopped the motor won't turn. The contacts can be worn to the point of not contacting or it may have sawdust or other matter between the contacts. Whatever the reason the contact is not making connection to the start winding.
Another method use is an "Inrush" relay. This may be located in the motor or anywhere else like the manual switch box or another box exclusively for the relay. Radial are saws frequently use this system. When the motor is powered up the current is several times the current that it takes to keep it running. This high current (inrush) is detected by the relay and snaps closed until the current falls to the lower running condition. In this design the relay is open at rest and closes for a small amount of time at power up.. In the first design the contact is closed anytime the motor is at rest and opens when up to speed.
Look for a fault in these areas.
There are many other ways to start single phase induction motors, but these are by far the most common.
Posted on May 12, 2013
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Band saw motor won't start just hums
You will need to take the motor out and check the brushes on the back also check the bearings you may need to disassemble the motor to repair.
Apr 05, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
Grizzly go691 10" table saw.
Make sure the motor is not bound-up by turning the shaft somewhat. Suspect a faulty power switch for the motor, also check for a thermal breaker on the motor--push to reset. It is not likely that the motor windings could have gone bad. Does the motor 'hum' when turned on? A start capacitor could have failed in that case. Contact the selling dealer for warranty help if you can't get it running again. Hope this helps!
Nov 19, 2010 | Garden
My Delta band saw motor is having issues. I was
I would bet it's the Motor Brushes.They are locaded on the housing of the saw, accesed by unscrewing the plug.The brushes are replaceable and your saw will be fixed.Where to buy replacents could be an issue,Check manufacturer or search power tool replacement motor brushes.If stuck you can try to unscrew the plug the brush is at the bottom engaging the motor armerure,there shoud be a spring keeping contact.Inspect brush condition it looks like a carbon block worn to the curve of the motor.Go online do a search on how electric motors work you'll see exactly what I'm explaining.Cheap part easy fix.Good Luck.
Sep 05, 2009 | Saws
Craftsman radial saw runs (hums) but wont turn over
The motor capacitor is dead. Replace it and it'll be right as rain!
Regards, --W/D--
Aug 05, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
Apr 11, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Saws Logo
87 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
