Question about Samsung Televison & Video
Can a faulty video board be repaired - Samsung Televison & Video
  • Samsung Master
  • 933 Answers
Yes it can, there are vendors who rebuild them. I don't know if it will be cost effect vs. buying a replacement board.
Posted on May 18, 2013
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
Won't run. lights work
see the video attached. Lube the rollers bearing too front+back. test the drive belt motor, for to loose or faulty belt and repair and replace.
However you must test the input voltage terminal motor, see my personal TIPS , if there are the motor is faulty.
Test the output voltage control board, for input voltage terminal motor, if there ARE not voltage , the board is faulty.
God bless you
Oct 20, 2013 | Reebok 8700 ES Treadmill - Silver Service...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
Faulty Samsung lcd tv LE40R87BD
Prices continue to drop precipitously and a repair or replacement of the board is gonna be expensive. Better off with new set and new warranty.
Aug 03, 2017 | Televison & Video
Turn tv on, audio but only flashing pic, then turn off and turn back on same thing, 3rd time have full pic
This problem will occur under two circumstances
1, Faulty electrolytic capacitors in the power supply board
2. Faulty back light inverter board.
Fist of all check is there is any faulty capacitors in the power supply board. If you find or not try to replace all the electrolytic capacitors in the power supply board. In most cases this will solve the problem. I have added the some video which will help you
The second one is the inverter back light inverter board. There is no repair possible with the inverter board. You have to replace the board with a new one. As you didn't mentioned any model number of your tv its not possible to attach a picture of the exact inverter board. The back light inverter board will look like one in the picture
Ajin
Feb 09, 2012 | Sanyo 42 in. LCD TV
Colours on the screen have lost red and all the recommended solutions seem useless. What else can I try?
If you connect your desktop to another external screen, you will instantly know whether the fault lies in the video processing, (Mother/Video Board fault), or the desktop screen is faulty.
If it is Mother Board, there is not much you can do except check the drivers are OK by substitution.
If it is a faulty Video Board, replacement will let you know if it infact was that at fault. Check the cable leaving the Desktop and at the screen end, there may be a bad connection. If not the screen has a fault and will have to be replaced.
If you require a new screen, visit ebay, there are always suppliers there at reasonable prices for the DIY repaires or take it to your HP repairer.
Hope this helps.
Nov 29, 2010 | HP Computers & Internet
Display problem due to mother board not accessing the RAM
Motherboards that have an on-board video card/chip, uses part of the main RAM module for its video RAM. If the RAM module is faulty then there isn't any video RAM available and therefore the computer won't boot up.
Try re-seating the RAM module first and see if the computer boots up.
If not, remove the RAM and take it to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty then replace the RAM.
Sep 27, 2010 | Intel D845GLLY Motherboard
No picture
Try doing the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The Sustain board may be faulty.
Ysus and Zsus boards have the function of sustaining voltage on the plasma display cells.
When a Sus board is faulty you can get no screen.
This is the most common reason for dark screen or no raster on plasma TVs.
Buffer board.
Usually faulty buffer board causes picture problems, or a line on display, however in same case this can also cause no picture.
The main controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Sep 05, 2009 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
