Question about Wolfgang Puck Bistro 1400-Watt 3-Tier Rapid Food Steamer
Steamer parts How can I replace one of the plastic steamer trays? It has cracked and broken.
The lid of my EP91 quad blade is broken
Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Mar 16, 2016 | Euro-Pro EP91 Quad-Blade Food Processor
Stopped emitting steam
Mine started steaming from the top and a little plastic piece inside where the handle attaches to the wand cracked. I had to purchase an entire head and after one use it did the same thing again. It is a poorly made steamer with cheap plastic parts! Since it was out of warranty, I threw it in the dumpster!
Mar 24, 2014 | Oreck Steam-It All-Purpose Steam Wand
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plastic lids
The parts and warranty number for Salton, Inc is:
Applica Consumer Products
1-800-231-9786
Jan 01, 2009 | Salton RA5 5-Cup Rice Cooker
Cracked plastic
Yes- this is a very common problem with the Bunn home coffee brewers. However, there are no replacement parts available. Your only hope to get a replacement pour-in tray is to get ahold of yopur local Bunn repair center and see if they have a machine that broke down for some other reason and rob the tray from that. You can get a list of Repair centers in your area from www.bunn.com
Oct 04, 2008 | Bunn NHB Coffee Maker
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Replacemtnt adult tray
ok there is a way to fix old one
ever hear of j.b weld industrial epoxy bondo i dont know the ingrediant they kept the secret of the sauce
well this is a great product for fixing things mostly cracked engine blocks that can with stand heat and preasure
this will work the same with broken clip you just prep area to be j.b. welded with sand paper
mix the jb weld per instructions on package
use a piece of small plastic about 1/2 in wide 4 inches long this is to apply the jb weld
to broken pieces let set over night and this will be hard as a rock and shouldnt break again
only mix little portions at a time
ive looked myself for the replacement adult tray and couldnt find them so my next step was to repair it this has worked well for me
May 21, 2008 | Graco Quattro Tour Travel System
Replacement basket for Black & Decker HS800 Flavor Scenter Rice Steamer
I would not recommend replacing just the plasic basket, too expensive. Once the plastic parts begin to fail, the uint has seen better days (our basket was still ok, but the unit started to leak out the bottom and the timer would stop during the steaming).
Bought a replacment B&D Handy Steamer, oval shape allows longer food items to be steamed (approx 10"x8"), water res & can be filler while steaming. Price was $25 in local hardware (Jan 09). Not worth fixing the old one IMO.
Apr 14, 2008 | Black & Decker HS80 Rice Cooker
Wolfgang Puck Bistro 1400-Watt 3-Tier Rapid Food Steamer Logo
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
eyecam
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
