Question about Homelite 33cc 38cc 45cc Chainsaw Oil Pump Pa01396
Need replacement part
Need the cover you take off when changing the bar or chain.
    New Friend:
  • 3 Answers
Google Homelite PN# 310508001 and you will find it at many locations
Posted on May 14, 2013
Change chain
Loosen and remove bar lock nuts and cover. screw tensioning screw to loosest point. wrap chain onto teeth of drive sprocket, then within grooves on bar. Be certain cutting edges are facing forward. Look at chain before removing. set bar with new chain to ensure the tension pin aligns with bar tensioning hole. Replace cover set nuts loosely. Tighten chain to about 1/4" out of groove when pulled on (wear gloves). Tighten nuts, spin chain to see it moves freely but does not hang free og bar groove. re-tension as necessary. Happy cutting!
Jan 04, 2015 | McCulloch Oregon 14" Chain for Mac Cat 351...
Change chain on husqvarna chain saw
loosen bar nuts loosen chain tensioner then remove the loosened bar nuts and cover. remove bar and chain from machine and then chain from bar. install new chain
Sep 16, 2014 | Husqvarna Garden
Changing the chain on chainsaw
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
Nov 24, 2013 | Husqvarna 455 Rancher 555cc 35 hp 20"...
How do I change chain on a 14" mc culloch saw
As you do not say what model we are talking about, i will go through the standard procedure.
If it has a chain brake make sure this is de activated by pulling the hand guard fully back to the top handle, remove the nut/nuts from the side cover, remove the cover, pull the bar away from the adjuster pawl, this will slacken the chain enough to loop the chain from the bar and off the sprocket, screw the chain adjuster fully back ( this may be in the crankcase or in the side cover ), with the guide bar now fully back loop the new chain over the sprocket, and lay it into the bar rails, with the cutters sharp edge facing away from the saw on the top of the bar ( the chain rotates clockwise as you are looking at it ) replace the side cover, if the adjuster pawl is in the cover make sure the pawl aligns with the hole in the guide bar, refit the bar nut/nuts finger tight, adjust the chain so as it touches all the way around the guide bar, with a gloved hand pull the chain around the bar to make sure it is fully into the sprocket, re tention the chain if required, hold the nose of the bar up and fully tighten the bar nut/nuts.
Once the saw has run for 10 minutes there will be an initial stretch, so you will need to re tention it.
Hope this helps.
Mar 01, 2011 | McCulloch Garden
Change blade
all chain saws have a sprocket that the chain runs on this sprocket is what make the chain rotate on the bar. the bar is the long part that sticks out in front of the motor. you must remove the side cover of the saw to access the sprocket region of the saw. be sure the saw is unplugged and then remove side cover the bar is usually held in place by a couple of bolts. on gas saws these two bolts also hold the side cover in place and must be removed to replace the bar and chain. once you have removed the side cover look for bolts holding the bar in place. if you only want to change the chain then you may be able to only loosen the bolts or screws holding the bar in place.there should be a screw to adjust the bar forwards and backwards. this screw put tension on the chain so when you put a new chain on turning the screw will proberly tension the chain /do not overtighten the chain.
also be sure you put the new chain and blade on the same as the old one that comes off trying to cut with a chain that is on backward does not work. last note if you are replacing the blade because the old one is dull take the saw to a saw shop they can sharpen the exsisting chain and save you money.
Jan 24, 2011 | Remington Electric Chain Saw
Need to replace chain on farm boss with 20 inch bar how do i get to sprocket to get old chain off
Release the chain brake. Remove the nuts/bolts that hold the right hand cover over the drive end of the bar. With the cover off, the bar will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting teeth! Clean the side of the engine where the bar fits to, and the small oil passages in the bar drive end that run from the large holes out to the chain groove on each edge. Also clean the entire chain groove. Fit the new chain to the sprocket, then insert the bar and work the chain onto it. Pull out on the bar until the chain fits fairly tight, then fit the cleaned cover over the drive. You may have to change the position of the chain adjustment screw a few turns to allow the adjustment 'tang' to drop into one of the large holes in the bar. Make sure the cover is fully seated, then run the fasteners down finger tight. Turn the chain adjuster screw CW until the chain pulls up to the bottom edge of the bar, but not so tight that you can't turn the chain by hand. Tighten the fasteners fully and recheck chain tension. Start the engine and run the tip of the bar near some cardboard at speed for a moment or two--proper oiling is indicated by a thin line of oil thrown onto the cardboard. Be sure to keep the chain teeth sharp and properly adjust chain tension--don't allow it to droop when cutting. Hope this helps!
Dec 08, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
Can i get instructions to download on how to change the chain on my homelite 33cc chainsaw with 14.35 chains
Got to homelite.com and input your model number.
WARNING:
When servicing, use only identical Homelite
replacement parts. Use of any other parts may
create a hazard or cause product damage.
WARNING:
Always wear safety goggles or safety glasses
with side shields during power tool operation or
when blowing dust. If operation is dusty, also
wear a dust mask.
GENERAL MAINTENANCE
Avoid using solvents when cleaning plastic parts.
Most plastics are susceptible to damage from
various types of commercial solvents and may be
damaged by their use. Use clean cloths to remove
dirt, dust, lubricant, grease, etc.
WARNING:
Do not at any time let brake fluids, gasoline,
petroleum-based products, penetrating
oils, etc., come in contact with
plastic parts. Chemicals can damage, weaken or
destroy plastic which may result in serious
personal injury.
LUBRICATION
All of the bearings in this product are lubricated with
a sufficient amount of high grade lubricant for the
life of the unit under normal operating conditions.
Therefore, no further lubrication is required.
REPLACING THE guide BAR AND
CHAIN
See Figures 34 - 43.
DANGER:
Never start the engine before installing the
guide bar, chain, clutch cover, and clutch drum.
Without all these parts in place, the clutch can
fly off or explode, exposing the user to possible
serious injury.
maintenance
Fig. 34
Fig. 35
Fig. 36
WARNING:
To avoid serious personal injury, read and
understand all the safety instructions in this
section.
n Always place the switch in the stop “ ” position
before you work on the saw.
clutch
cover
Run
Position
sprocket
Page 26 — English
cutters
bar
groove
chain drive links
Fig. 38
maintenance
chain rotation
chain drive links
Fig. 37
n Make sure the chain brake is not set by pulling
the chain brake lever/hand guard towards the
front handle to the run position.
NOTE: When replacing the guide bar and chain,
always use the specified bar and chain listed in
the Bar and Chain Combinations section later
in this manual.
n Wear gloves when handling the chain and bar.
These components are sharp and may contain
burrs.
n Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed.
n Remove the bar and chain from the mounting
surface.
n Remove the old chain from the bar.
n Lay out the new saw chain in a loop and
straighten any kinks. The cutters should face
in the direction of chain rotation. If they face
backwards, turn the loop over.
n Place the chain drive links into the bar groove
as shown.
n Position the chain so there is a loop at the back
of the bar.
n Hold the chain in position on the bar and place
the loop around the sprocket.
n Fit the bar flush against the mounting surface
so that the bar studs are in the long slot of the
bar.
n Replace the clutch cover ensuring that the
adjusting pin in the clutch cover is in the bar
chain tensioning pin hole and that both bar
studs are securely in their respective holes in
the clutch cover.
NOTE: The adjusting pin may need to be slightly
repositioned with the chain tensioning dial so
that it is aligned with the position of the bar chain
tensioning pin hole.
n Replace the clutch cover and rotate clutch
cover lock knob just enough to hold the cover
in position.
NOTE: The bar must be free to move for chain
tension adjustment.
n Lift the tip of the guide bar up to check for sag.
n Remove all slack from the chain by rotating the
chain tensioning dial clockwise until the chain
seats snugly against the bar with the drive links
in the bar groove.
n Release the tip of the guide bar and, if the chain
sags, turn the chain tensioning dial clockwise.
Repeat this process until sag does not exist.
n Hold the tip of the guide bar up and tighten the
clutch cover lock knob securely.
Jun 25, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
How to change cahain saw blades
If you want to change the chain bar you need to remove the cover on the side the bar enters. This is usually done with with a 1/2 inch wrench or if the tool-less model, completely loosen the hand nut on the side until it comes off. You will be able to how the bar is installed under this cover. Make note of the direction of the chain teeth to insure you put the chain back on correctly.
It is better to wear gloves when working with the chains also. Install the new bar and reinstall the side cover and retaining nuts. Snug up the nuts but not tight, adjust the chain with the chain adjusting screw or thumb-wheel for about a dime's width play between the bottom of the chain bar and the chain midway along the bar.
Jun 15, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need info on how to change Chain
View the first 1:15 of this:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Install the new chain like this:
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Yours is electric there are probably a few differences but the process is very similar.
Nov 12, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Changeing chain
Sure, all are very similar and I can tell you without a manual. Loosen the nuts that holds the chain bar to the body. Loosen the slot headed screw that tensions the chain on the bar,( you may have to dig into some stuck on sawdust that may cover the screw) then pull the chain and bar off together. I would flip the bar over to get the advantage of a good square surface for the new chain to wear against on the bottom. Now make sure the cutting bits on the new chain face away from you on the top as it moves on the bar and you are set to replace it on the mounting studs. When you replace the sprocket cover, make sure the tensioner peg goes into the bar slot then snug up the bolts a bit and tighten the chain til you can pull it away about 1/2 inch from the bar when properly tensioned. now further tighten the bolts and enjoy.
Dec 03, 2008 | Poulan Pro Chain Saw 46cc 20"
Homelite 33cc 38cc 45cc Chainsaw Oil Pump Pa01396 Logo
70 people viewed this question
Top Homelite Plumbing Experts
DROPNDEAL
DROPNDEAL
richie46
Gil Shultz
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
