Question about Mtd Craftsman 4Cycle Mini Tiller
Spark plug My mini tiller mod.# 316-29264 keeps stalling after about 5 mins of use. It restarts fine then it happens again
2 Suggested Answers
  • 10865 Answers
SOURCE: tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Posted on Apr 24, 2009
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
JD JS45 walk behind mover. Starts, runs fine for 5 minutes, then stalls, won't restart till i pull the spark plug and cool the motor, plug down. then same thing starts, runs for 5, stalls.
Probably either a fuel or a spark problem. You need to check for the presence of a good spark immediately the engine stops - by using a spark gap, a spare spark plug or a propriety spark indicator.
If the spark is found to be absent the fault is likely the ignition module but check all connections and the stop switch operation before replacing.
If the spark is present then the fault is probably fuel-related and is the sort of thing a tiny droplet of water in the carb could cause...
Jul 23, 2016 | Cars & Trucks
1989 mercedes 560 sel, gas, w126/ Car cold starts every morning and idles for 10 min. then stalls
the idle control motor probly worn-on the throttlbody--also the tps sensor - get intake area inspectd--a haynes manual will xplain complete car-partstore hazit--------starter fluid is used for low compression or weak spark
Dec 25, 2013 | Cars & Trucks
I used my tiller one time and the second time I used it, it was hard to start and when she did, she blew white smoke and would not start after that.
This happens frequently after a tiller, mower, snowblower, etc. sits for a season. Your tiller is probably flooded due to a stuck carb float. You can try a quick fix by tapping gently a few times on the float bowl, then pulling the spark plug and cleaning it with a wire brush, and then wiping it dry with a cloth. If you have a new spare plug to install, that is even better.
Try to start your tiller again, and if the same thing happens, your float is still stuck and you may need to have your carb serviced.
You can try one more alternative if you do not want to go through the bother and cost of having your carb serviced (or purchasing a kit and trying to do it yourself), but it is a 50/50 "hit or miss" sometimes it works, sometimes it don't type thing:
Drain all the gas out of your tiller. put about 2 ounces of carb/injector cleaner in the tank, and top off with gas. Give the float bowl a few taps. Now, pull the spark plug..... make sure the spark plug wire is at least 1 inch away from any metal. With the throttle set to full and the spark plug removed, Pull the starter cord 5 or 6 times (if you have electric start, crank it for about 5 seconds). You may see some vapors come out through the spark plug hole- this is OK.
Clean, install, and connect your spark plug (again, a new plug is even better). Give the bowl a few taps for luck, and try and start your tiller again. If the procedure worked, your tiller may run rough for 10 or 15 seconds (maybe even up to a minute or so... let it take its course!), but then smooth out.... if it stalls, don't worry.... Start it back up.
This will often work for tillers, snowblowers, mowers, generators.... pretty much any 4 stroke "lawnmower engine". It all depends on how badly the float is stuck after the engine sits.
You can minimize having this problem in the future (it may still happen, but less often and less severe) by adding a good fuel stabilizer (such as the brand name STA-BIL) to your gas and running for 10 minutes or so before you store your "lawnmower engine" for the season.
If you still have problems, the likely cause is a stuck carb float and the carb will need to be serviced.... but hopes are high that my solution helps!
Good Luck, and Thank You for using FixYa!
Apr 20, 2011 | Garden
The tiller was working fine for about an hour. I let it rest for 15 min, then briefly turned it on its right side work on left wheel. It started right up, but then stalled about a minute later and won't...
Laying your tiller of its right side can fill engine breather with oil and possibly entering your carburator causing engine to smoke and then quite. If this is so change or clean your spark plug. It this is not the case your crankshaft seal may be bad allowing oil to enter your ignition point and condenser cavity causing points to get wet.
Mar 19, 2011 | Troy-Bilt Pony Garden Tiller
1999 saab 9-5 stalls without warning won't restart for 30-40 min.
Have you check the O2 sensors? How baout cleaning the MAF and Throttle body? Thermostat?
How does the temp gauge look whn it stalls?
Jun 25, 2009 | 1999 Saab 9-5
Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Mar 16, 2009 | Honda 25cc 4-cycle Mini Tiller
Mtd Craftsman 4Cycle Mini Tiller Logo
57 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
