Question about Xerox Office Equipment & Supplies
Copying problem WorkCentre 7232
Error 086-311 occured. IBT belt silver patch and sensor was cleaned. Error disappeared and the machine is now producing very faint copies with some letters not seen at all. Please help. What could be the problem for this to happen?
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
  • 4 Answers
SOURCE: Oki Printer c3200 error code
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Posted on Oct 27, 2008
SOURCE: lsu error
LSU ERROR
Posted on Nov 22, 2008
  • 1297 Answers
SOURCE: Error COF30
This code to refer on ATDC sensor malfunction.Check the ATDC sensor(auto toner density control) and the connection between the imaging unit and copier,replace the PWB-A board or replace the ATDC sensor.If the copier machine have more 120000 copies change the developer and perform the F8(ATDC level control process).
Posted on Oct 03, 2009
pineworks
  • 4041 Answers
SOURCE: getting
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Feb 10, 2015 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Xerox error 089 311
That error signfies a problem reading the IBT belt patch. Check patch and clean and inspect for scratches. It's on the inner side of the transfer belt. If problem still persists after cleaning, replace IBT belt, part number 064K92402.
http://www.iteminconline.com/itemdesc.asp?ic=064K92404&eq=&Tp=
Aug 25, 2014 | Xerox Workcentre 7132 Multifunction Color...
089-311 error code for xerox copier #7132
May 01, 2012 | Xerox Office Equipment & Supplies
Error 3-380 dc 12 xerox
its problem of IBT belt sensors
two silver colour patchs held on ibt belt check that patches its has any dust
or damage
replace that patches
Mar 06, 2010 | Xerox DocuColor 12 Color Copier
One machine dc12 it indicates3-380 what is the prablum
problem is with IBT belt sensor
there is two silver patches on IBT belt
check is it there?
or any dirt on it
clean it
Jan 30, 2010 | Xerox DocuColor 12 Color Copier
Error code 3-380 what does this mean
That error describes a number of things that can be foulty on your machine. First Did you recently replaced print cartridge (PC)? Couse if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes doest do their job anymore or maybe the sensor that "reads" that patch is dirty
Aug 05, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 What does code 3-380 mean and how can I correct it
Aug 05, 2009 | Office Equipment & Supplies
Doc 12 3-380 error
There is a silver patch on what is called the ibt belt. If you take out the drum cartridge you can see it if you look in at about the 7 o'clock position. You need to take that belt out to clean it however. If your happy you can do that let me know
Oct 23, 2008 | Xerox DocuColor 12 Color Copier
Doc 12 Error Code
You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
Feb 14, 2008 | Xerox DocuColor 12 Color Copier
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
