My copier Workcentre Xerox 7232 displaced error 089-311. I removed IBT belt and cleaned home position sensors and silver patch on the belt. The error message disappeared but when photocopying very faint copies are produced with some words being not seen at all. please help. what should I do?
  • Bleddyn Jones May 22, 2014
    Ensure that the ITB assemblyy tension arms are in the down position. They are located at the front and rear of the ITB assembly, they are to be locked in the down position after reinstallation via the left hand door.
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
Posted on Apr 19, 2009
SOURCE: PHASER 7700 ERROR 30
Error 30 :Belt Home Too long
  • 64 Answers
SOURCE: xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
Posted on Jul 17, 2009
SOURCE: Xerox WorkCentre 7232 will not Scan to PC
Did you ever find a solution to this problem. We are having the same problem on our Docucolor 242. The first two "SCAN to PC" jobs work fine, but we get several 016 errors for any jobs after that. This machine had been working fine for 18 months before this started happening a week ago.
Posted on Nov 17, 2009
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Feb 10, 2015 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Xerox error 089 311
That error signfies a problem reading the IBT belt patch. Check patch and clean and inspect for scratches. It's on the inner side of the transfer belt. If problem still persists after cleaning, replace IBT belt, part number 064K92402.
http://www.iteminconline.com/itemdesc.asp?ic=064K92404&eq=&Tp=
Aug 25, 2014 | Xerox Workcentre 7132 Multifunction Color...
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
089-311 error code for xerox copier #7132
May 01, 2012 | Xerox Office Equipment & Supplies
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Error 3-380 dc 12 xerox
its problem of IBT belt sensors
two silver colour patchs held on ibt belt check that patches its has any dust
or damage
replace that patches
Mar 06, 2010 | Xerox DocuColor 12 Color Copier
One machine dc12 it indicates3-380 what is the prablum
problem is with IBT belt sensor
there is two silver patches on IBT belt
check is it there?
or any dirt on it
clean it
Jan 30, 2010 | Xerox DocuColor 12 Color Copier
Xerox DC12 error code 3-380
chungo
tensioner roll ibt ko, backup roll fuera de sitio, tro sensor sucio, halftone pwb ko....
Oct 22, 2009 | Xerox DocuColor 12 Color Copier
Doc 12 3-380 error
There is a silver patch on what is called the ibt belt. If you take out the drum cartridge you can see it if you look in at about the 7 o'clock position. You need to take that belt out to clean it however. If your happy you can do that let me know
Oct 23, 2008 | Xerox DocuColor 12 Color Copier
1,980 people viewed this question
k24674
