Question about HEWLETT-PACKARD Products - HP - Roll Feed Spindle (HPProductsQ6709A) for Designjet T610, 44" Long - Sold As 1 Each - HP Spindle
Error 42:10 hp desingjet t610
Scan axis lenth (1064736) too short
  • HEWLETT-PACKARD Master
  • 783 Answers
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Hp designjet 9000s system error 1701
The Paper-Axis or the Scan-Axis Motor moves the Carriage, but the input from
the Linear Encoder Sensor does not change.
You are going to need a tech to check out the plotter.
Dec 11, 2013 | HP DesignJet 9000 InkJet Printer
Hp designjet z6100 42:10
error code 42:10
Electrical fault in Carriage Motor or starting the Scan Axis or Homing Scan Axis.:
it is not uncommon to find that the encoder is the fault behind the error code,
in the User manual there is a procedure for Cleaning The Encoder Strip. you should follow these steps carefully
.A Z6100 User manaul is available to download at HP.com link as follows:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?cc=us&contentType=SupportManual&prodSeriesId=3338748
the user manual is located near the bottom of the page
Sep 25, 2013 | HP Designjet Z6100 InkJet Printer
Hp desinjet t610 error code 02.01.10
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If error comes back, call a tech. There is a problem with the Carriage Board or Trailing Cables
Aug 14, 2013 | HP Designjet T610 InkJet Printer
Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Possible paper jam.
3 Mechanical Initiator scan axis measure error.
4 Check that the Scan-Axis Motor is correctly connected.
5 Check that the Encoder Sensor is correctly connected.
6 Remove the Encoder Strip and clean it.
7 Perform the Scan Axis diagnostic test to troubleshoot the problem further
Jul 03, 2013 | HP Designjet T1100ps Printer
Hi, In the office we have a hp designjet T610 plotter. but today it appears an error code 48:00 in the screen, after restar the hp designjet shows the same error, please, I need your help!
It is a PPS system failure(Pen to Paper Space).
Turn power off and pull the plug from the wall outlet.
Reconnect and power on.
In the Diagnostics perform the Scan Axis PRS diag test.
If it still fails a tech is going to have to look at it.
Sorry, but this may need parts replaced. A print mech board or the PPS solenoid.
Mar 25, 2011 | HP Designjet T610 InkJet Printer
My plotter is saying that there is an error, number 87:10 What is this, and what can i do do? Its a HP Designjet T610.
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
Mar 23, 2011 | HP Designjet T1100ps Printer
Hp desingjet 500 plus 24"
code error error 21:10 for hp designjet 500 24''
Dec 08, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
Hp t610 when we switch it on it will more tim e to
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-167.
�� If the System Error continues, replace the Main PCA.
this is the definition from the service manual, hope this helps.
Jun 06, 2009 | HP Designjet T1100ps Printer
HEWLETT-PACKARD Products - HP - Roll Feed Spindle (HPProductsQ6709A) for Designjet T610, 44" Long - Sold As 1 Each - HP Spindle Logo
125 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
