Question about Indesit Washing Machines
Indesit 1263w washing machine blocked
How do i clean the filter/check the pump?
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
barkencoa
  • 3463 Answers
SOURCE: Hi i have an indesit
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Posted on Jan 30, 2009
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Posted on Jan 15, 2010
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
Where can I get a manual for my Indesit 1063W
I scanned and uploaded a copy of the user manual for the Indesit 1063W washing machine here
http://notes.minty.org/cgi-bin/wiki.pl?Indesit_WN_1063_WG_Users_Manual
Dec 21, 2009 | Washing Machines
Washing machine will not empty
check electric connection on the pump and check pump electro motor.
Feb 16, 2009 | Indesit W 123 Front Load Washer
Machine not pumping out
blocked pipes or no power to pump, check in that order, but clean any filters out first, cheers
Jul 05, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing machine problem
probably filter blocked. if memory serves me right, filter is located in pipe from sump to pump. remove bottom back panel. remove sump hose where ir is clamped to tub and filter is inside this pipe, take out and clean
Jun 18, 2008 | Indesit W 123 Front Load Washer
INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Apr 18, 2008 | Washing Machines
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Jul 17, 2007 | Indesit W 123 Front Load Washer
Will not spin
When your water does not drain or spin, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked. There is a small door on the front, below which is the place you have to clean out first.
Dec 05, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
