Bios not acpi compliant - Computers & Internet
    Sergeant:
    Champion:
  • 242 Answers
If I remember right when install windows xp you hold f5 or f7 when the blue screen comes up and its detecting everything until it says to install and it will disable acpi.
Posted on May 27, 2013
rickatnight1
  • 72 Answers
SOURCE: acpi compliant!
Why would you want to do this? I highly recommend against it.
  1. Go to Device Manager and select Computer -> Properties of ACPI PC
  2. Click the driver Tab and choose Update Driver. When the wizard gets to the "What do you want the wizard to do?" page select "Display a list of the known drivers..."
  3. Then "Show all hardware of this device class"
  4. Then select "Standard PC"
  5. Reboot the machine.
Posted on May 14, 2008
  • 12 Answers
SOURCE: Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Posted on Mar 21, 2009
Tech_Mania
  • 239 Answers
SOURCE: Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
  • 235 Answers
SOURCE: netbook bios not fully acpi compliant
you are experienceing the blue screen of death, if these happened to yo have your netbook check by a qualified laptop tech to avoid any hardware damages
Posted on Nov 22, 2009
drifterK
  • 4924 Answers
SOURCE: Toshiba Satellite M45-S331 notebook, os xp. Change
The thing is that windows xp ..usually does not have the drivers for teh acpi or achi mode and you need to get into bios and disable teh mode and let the hard disk to run in IDE compatible or sata as ide..
the function can be disabled in the same screen where teh hard disk and other sata and ide devices are presented..
After you disable the achi mode..it will work ..remember that you have to save changes with F10 before exit bios..
another way to make this work ..is install the windows xp in this mode..after you are done ..just install all drivers for it ..including raid and ahci drivers..and change it back from bios..It may work ..if it sees the drivers..
or ..you need to install the drivers when you get to teh press F6 to install 3rd party drivers....and you have to find a way to get them ...cause this operation is done usually b yusing a floppy diskette so ..to have a chance to do it .. you need to try to install them from a usb or install windows from usb and use the disk with drivers in the optical drive ..
If I would be in your place I would not complicate myself and just go to bios and change the bus mode for the hard disk ..save changes and reinstall operation system if needed..or go on from where it was..It will see the hard disk and no longer give you the blue screen
Posted on Jan 07, 2012
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
BIOS Acpi Not Compliant
You will need to go to the website for the motherboard manufacturer and download the updated drivers for that motherboard. This is common with all the changes that windows goes through in a life cycle.
Nov 23, 2011 | Computers & Internet
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
RESOLUTION
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Acpi compliant
BIOS has no upgrade for VISTA to be installed. Contact the manufacture to write on update BIOS for that computer or motherboard as the case may be.
Dec 22, 2008 | Intel D845PT (KD845PTPAK10) Motherboard
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
