Question about Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter
Mic problem with the behringer djx750
Cant hear the mic when pluged into the tape output,,,got a sound card plug into the master so i cant use that??
4 Suggested Answers
SOURCE: Hi i have djx 750 and i have connect the master
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Posted on Dec 27, 2009
  • 5603 Answers
SOURCE: have a Behringer 1202 Xenyx
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Posted on Jul 11, 2011
  • 1212 Answers
SOURCE: HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Posted on Apr 27, 2012
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No output from master out
Make sure channel(s) are assigned to stereo output
Mar 30, 2011 | Behringer Pro Mixer Djx750 Professional 5...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main...
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Aug 05, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Dec 03, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter Logo
57 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
