Question about Brother GX-6750 Typewriter
Code I cannot find an @ key anywhere is there a certain code that will fix this?
  • Brother Master
  • 3,594 Answers
You are probably in KBII Mode The code key with the top row key with KBII labled above it should get you out of that mode.
DickyO
Posted on May 21, 2013
Where is the fuel reset button on 2001lincoln town car
Look inside the trunk (after assuring there are or has been no fuel leak anywhere) On the drivers side trunk hinge there should be a switch labeled "Reset"..
Be certain the ignition key is off and out of the ignition first. Press the "Reset" switch as described firmly. Return to the ignition switch and turn the key to the "on" position only for about 5 seconds. (Do not start the engine) Then turn the key back to the "off" position. Check for any leaks under the car before attempting to start the engine.
Nov 02, 2017 | Cars & Trucks
How to code a new key to a toyota 2004 model
key codes are dealer issued --if you have a good working key their are some locksmiths and a few stores [some larger named hardware,home stores ] can cut certain electronic keys the following links show how to do programming on certain 04 toyota s but its even specified in links that it doesnt work all the time
2004 Toyota Sienna LE Immobilizer Key Programming How To Toyota Ignition Key Programming
Oct 24, 2016 | Toyota Cars & Trucks
I need the ignition key code for a 2007 ford f150 xl, and the dealer said it could only go back five years. Can I find it anywhere myself?
96 million codes for this year. Sorry, you have to pay the price and have it redone. Two keys and a reprogram. Also have to fix what is bad.
Jul 11, 2016 | Ford Cars & Trucks
Unlocking my phone
You will probably not be able to unlock it for free. And I don't recommend using free codes regardless of where you acquire them from. The reason is that services which provide free unlock codes generally do not verify if the unlock code will indeed work with your handset or not. Unlike most paid services which do verify.
The reason I would advice you against free unlock codes is that you only get a certain number of unlocking tries after which your phone will be locked permanently.
Apr 30, 2013 | HTC Cell Phones
Lost keys, no key code yamaha radian
Hi, Loopsta_009 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
need key for Radian YX600
Lost my bolt only key
Yamaha YX600 Service Manual
OEM parts for Yamaha
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Aug 01, 2012 | Yamaha YX 600 Radian Motorcycles
Number and letter keys are stuck (type) together
This model has no numlock as it has no keypad. It looks like a faulty keyboard as the linked keys appear to be in the same column in the keyboard grid. You could try Fn+F11 as this solves certain other keyboard problems with symbols etc. Otherwise could be a new keyboard required.
May 29, 2012 | Dell Inspiron 15 Laptop
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions...
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions from the internet anywhere? The keys have 128 written on them but I cannot find any further I.D numbers anywhere. Thankyou very much for your assistance
May 21, 2011 | Safe International Digital Electronic Safe...
I've managed to lock my phone and need to enter a puk code but i cant find it anywhere?
Hi, I think you referring to a SIM lock, and apparently the sim is now on locked stage.and it will ask for the Personal Unblocking Code (PUK) for 10 Times. For the code, you should liaise with your operator. in the mean time do not try to enter any random numbers - if you tried 10 times, the sim will be permanently block an you wont be able to get your contacts back on that particular sim.
Thanks, Ramaly
Feb 28, 2011 | Samsung Galaxy S GTI9000 Smartphone
2000 olds intrigue. Security light stays on the heater don't blow and the anti lock break stays on. it was put on a scanner and it said no codes found. any suggestions?
It's when the security light starts flashing that the infamous "chip" in the key becomes a nightmare to many. Gradually the car begins not cranking anymore or if it cranks it would start and die in a second. Randomly it will do this more and more often until it won't start anymore. VATS, PASSkey and Passlock immobilizer systems are killing cars all over North America, they have a short lifespan and are certainly more effective against owners than thieves. Here is how you save your car
1st trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year. If its shuting down while running, im sorry i have no quick fix...
Cheap fix: Bypass the chip in your key. Temporary, but effective. Until the TDM (theft deterrent module) in the dash poops out, then you're kinda screwed. I was told that these types of key security systems have a 7-10 year life span. Sucks for us. This link explains the "Key Issue" pretty well.
----- http://vats.likeabigdog.com/
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. For a list of cars effected by this problem. See the NEWROCKIES link on the right side of their page......... They sell a unit for 200 bucks to totally bypass this system FOREVER. life time-money back and all that. Finally did this in my car. Well worth the 200 if you've looked into getting this replaced... Anywhere from 600-1000 bucks.
----- http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
Jan 29, 2011 | 2000 Oldsmobile Intrigue
Use Special key for feature code
Need to disable SPCL Key Required for feature code entry in system flags, But you may have a numbering conflict in you system with a ext. and a feature code.
Sep 10, 2008 | Inter-Tel Axxess Phone 5504400
Brother GX-6750 Typewriter Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
