Question about Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25
What kind of oil is inside and how much is there.
What kind of oil should be used ?
Read the owners manual from the car or call the service department at the local dealer that services the car. Open the hood and find the white label inside the engine bay that tells about the engine displacement, that label might have the type of oil you need. Determining what kind of oil is needed has something to do with your geographic area (how hot or cold it is in your local area) and how much you drive the car....
Mar 22, 2015 | Cars & Trucks
350 built chevy motor is getting oil in the radiator?
This may be due to a bad trany cooler inside the radiator, if its engine oil then it may be a bad intake or gasket, first detremine what kind of oil motor oil or trany oil.
Oct 08, 2010 | 1992 Daihatsu Charade
What kind of motor oil do i need for 2003 bmw 325i
use a 5/30 synthetic oil..its good for winter and summer.
Apr 01, 2010 | 2003 BMW 325
My van leaks hydraulic fluid from near radiator
if your sure it is not transmission fluid,or antifreeze,the only other kind of oil around the radiator is the oil inside the AC system
Dec 29, 2009 | 2000 Dodge Caravan
Location and replacing an oil pump
oil pump is located inside oil pan, you would have to drop oil pan to get to pump.if lower engine is noisey you should check bearings also maybe even replacing them.kind of a big job.
Oct 02, 2009 | 1997 Chevrolet Tahoe
What kind mantenimence do you need give inside of
none- those motors have sealed bearings. they require no cleaning nor oil
Sep 08, 2009 | Dewalt D24000S Wet Saw With Stand
What oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Jun 29, 2009 | Submersible Systems Submersible Sump...
Talon oil feeder wont oil chain 38cc tree hawk
hi
first check the oil filter from the oil tank,the oil hose,remove the oil pump and check it(especially the plastic gear inside,if it worn is because of the bearings from crankcase).Clean the holes where oil goes.
bye savumihai71
Jun 08, 2009 | Garden
Can't re-lock printer back cover.
You can use less greasy oil or something like the vehicle engine oil.
Any kind of thin lubricant is always yield good results.
Do not use vegetable oil or cooking oil/sunflower oil etc.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25 Logo
79 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
