Question about Troy-Bilt TB144 26cc 4-Cycle Gas-Powered Cultivator-Tiller with Edger
Replacing drive shaft - Troy-Bilt TB144 26cc 4-Cycle Gas-Powered Cultivator-Tiller with Edger
Replace rear seal (drive shaft) on manual trans and started leaking badly
Drive shaft have only one seal and seal rear side on metal bush
1 jak up littil gear box because after shaft remov ing time oil no feldown
2 remove drive shaft rear bolt
3 mesher drive shaft seal touching area
4 mesher drive shaft Bush touching area this area damage want send machine Shoppe bush cover and drive shaft that time send seal also
Damege change that Bush also
Apr 25, 2016 | 1998 Isuzu Amigo
How do I replace the upper drive shaft on a Ryobi RBC430SEC brushcutter?
I couldn't find this model on google, but when replacing drive shafts in most brushcutters we used to slide the cutting head / gear assembly off the bottom of the shaft, remove the circlip holding the drive shaft if there was one, slide out the shaft from its square hole in the clutch at the motor end. If the shaft was broken we'd slide the motor part off the shaft to get the broken part of the shaft out.
Nov 10, 2014 | Garden
Yamaha V star Final Drive shaft
The drives for a 650 and an 1100 are different part numbers, so it probably wouldn't fit.
However, you can buy what parts you need to replace here:
http://www.bikebandit.com/houseofmotorcycles/2004-yamaha-v-star-classic-650-xvs65as-drive-shaft/o/m145479sch295406
Feb 16, 2014 | 2004 Yamaha V Star Classic
How to replace the drive shaft coupling on a 1995 toyota previa
I replaced my drive shafts on my 96 Previa LE SC, so I know it can be done. If you don't know the difference between the auxiliary drive shaft and the front or rear drive shafts, then you probably want to have someone do it for you. The auxiliary drive shaft coupling replacement is a difficult job. It is covered in manuals available in auto parts stores. $20 for the manual is worth it if you decide to do it yourself.
Mar 25, 2012 | Toyota Previa Cars & Trucks
How to replace offside drive shaft on 2001 rover 25
Mark drive-shaft and yoke to re-install in same location to maintain factory balance
Loosen and remove small "U" clamps at yoke end of drive-shaft
Pry drive-shaft out of yoke, pull off of splined end.
Oct 18, 2011 | 2001 Land Rover Range Rover
Vehicle shakes at 60 mph all wheels and struts replaced
Hello, Are the tires and wheels balanced? If they are balanced then check the drive shaft. This drive shaft transfer the power from the engine/auto transmission to the rear differential/rear wheel.
Now, on each end of the drive shaft is a flexible yoke, this splined yoke has a U-joint with four bearing cups. Two of the bearing cup is attached to the splined yoke and two are attached to the drive shaft. Now, on the rear differential end is a yoke but it has 4 bolts and nuts, it also will have a U-joint attached to the 4 bolted yoke and to other bearing cups attach to drive shaft. U-Joint is called "Universal Joint" Each U-joint has about 10 degree circular travel without any type of binding to the U-joints or the drive shaft.
Two things here. First, take a pry bar and wedge into the U-Joint and move the bar forwards, backwards, up and down. If the drive shafts moves in any direction and clanks. The u-joints need to be replaced and I would replace both of the U-joints. Secondly, if the U-joints aren't loose, then there is a good possibility that the drive shaft is out of balance. In other words, it has lost it small welded plats on the drive shaft and when you are drive you Chrysler the drive shaft is vibrating.
To replace the U-Joints and/or balance the drive shaft. You'll need to remove those 4 bolts and nuts on the differential yoke. Once the bolts are removed then push the drive shaft forward, it will slide forward. Now, under the transmission yoke place a pan/bucket/container to catch the transmission fluid that will drain out once the drive shaft is pull free from the transmission.
If you don't have a press, vise, brass 5 lb hammer, bushing, punches, then I would tackle this job of replacing these U-Joints. Without the proper tools, one can damage the U-joint yokes and the drive shaft. I wouldn't do this without the tools and experience. I use a cutting torch but I have been do it for 50+ years.
If the drive shaft is out of balance, then you will need to take to Drive Line Specialty Shop to have it balanced. Also, have them replace the U-Joints. They have all equipment to do this job. I wish you luck in your endeavor. GB....stewbison
Sep 21, 2011 | 2004 Chrysler Sebring
How to change and replace chain on 03 honda shwdow 750
are those bikes not shaft drive? i have 2 shadows and both are shaft drive as every shadow i have seen is shaft drive. there is no chain to replace
Aug 23, 2010 | 2002 Honda VT 750 DC Shadow Spirit
My drive shaft fell out, after the drive shaft was replaced I loose tramession floid from ware the drive shaft inserts into the tramession. Is this a seal problim and hpw dificult is to repair?
The seal was damanged when you lost the drive shaft. You need to inspect the transmission housing to insure it was not broken. Pull the drive shaft back out, Pry the seal out of the transmission housing and replace seal. Use a socket the same size as the new seal and lightly tap into place. Reinstall the drive shaft and you should be ready to go as long as the transmission housing is not damaged.
Aug 14, 2010 | 1995 Ford F150 Styleside Regular Cab
How to replace front drive shaft ?
Mark the drive shaft postion to the transfer case and front axle. Remove the bolts/straps from the transfer case and front axle pinion that hold the drive shaft in place. Remove drive shaft. You may have to drop the exhaust pipe for access.
Jun 02, 2009 | 1997 Dodge Dakota
Troy-Bilt TB144 26cc 4-Cycle Gas-Powered Cultivator-Tiller with Edger Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
