Question about Behringer SX4882
Behringer sx4882 wont turn on. And if I turn it off for a while it came back to live...
Wont turn on
Behringer Eurodesk-sx2442fx suddenly going into pink noise on main and aux outputs? Muting all channels did nothing. Fixed when powered down and back up. Scared to use it live now.
Behringer products are notorious for odd problems over time and are not well supported by the company. You can attempt to take it to the shop for repair, but honestly i'd just replace it than spend cash on a repair only to wait on the next issue to crop up.
Aug 31, 2017 | The Music
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
Where can I get a schematic diagram?
Try the Web.
BUT Behringer is very tight, wish you luck.
Peace-
Apr 10, 2016 | Behringer SX4882
How do I fix it?..
how are you hooked up? (hopefully you have this problem fixed by now. looks like you have 2 options for inputs. You can use xlr or 1/4" Are you hooking up to a sub as well or just flying these solo? Make sure your mixing board master is up, channel on mixing board is up, plug volume on speaker is up.. Im curious if you did get these fixed. Personally, I use qsc..
Dec 30, 2015 | Behringer Eurolive B212A Speaker
I have a behringer pmp5000. At Practice one of the cables was stepped on and came out of a speaker.then, plugged back in immediately. There was some smoke and now the unit wont even turn on. Can this be...
Yes, it can be repaired. Likely at least the output transistors are fried, possibly the drivers are too. Possible other components like resistors gone, too. Needs somebody that knows amps.
Jan 20, 2015 | Behringer Europower Pmp5000 Powered Mixer...
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I want to know the contact detail of Behringer Xenyx 502 Audio Live in Delhi, India
MUSIC Group Services EU GmbH Otto-Brenner-Strasse 4a
47877 Willich, Germany
Tel: +49 2154 9206 4149
Jan 27, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I have behringer speakers and my speakers just wont turn on. i checked the fuses. thats not the problem. what now?
The plural part of speaker makes me wonder, but let's not go there.
It's unlikely that the Behringer fairy is going to show up at your door, so try this support link and pick your circumstance. http://www.behringer.com/EN/Support/
Amplified speakers are annoying for this reason. If you overload the input from your computer sound card, you probably get the chance to blow both speakers at the same time. Amplified speakers without an amplifier aren't worth very much :-)
Apr 09, 2010 | Behringer Eurolive B212A Speaker
Behringer Eurorack UB1202 Prongs on power supply broke off, need to find where I can get a replacement power supply. x
Hey kfc-jake
Behringer the whole world wide are pretty good on spare parts. You could get a tech to replace the plug for you. Where abouts in the world are you and I can get you hooked up?
regards
robotek
Dec 07, 2008 | Audio Players & Recorders
Behringer SX4882 Logo
37 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
