Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
WD440 Lock Light Flashing
Hello, I have a Hotpoint WD440 (with the Mk4 board) I came back and the door was locked but door lock light was off and it had stopped mid-cycle (on final spin) I suspect I broke the handle at this point. I replaced the handle, this did not resolve I have replaced the interlock, this did not resolve I have just fitted a replacement board from EMW and run a cycle without any clothes in to see what it did. The door locked (light on) and it commenced It has gone all the way through to final spin again and then the door lock light has gone off (but the door remains locked) When it stopped the WASH, RINSE & SPIN and FINAL SPIN lights were lit solid and the ON/OFF is solid, the door is locked still, and the machine has stopped doing anything. I have switched off, after 5 mins, door will open. Switched back on, and selected "FAST SPIN" on the dial. Door locks (with a clunk) and the FINAL SPIN light is solid, ON/OFF light is solid but the DOOR LOCK light is out...after 5 minutes or so the DOOR LOCK light flashes. What is wrong with it please, I thought the board was going to resolve this
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Posted on Feb 28, 2008
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
beltronic205
  • 1460 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
barkencoa
  • 3463 Answers
SOURCE: wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Posted on Jan 30, 2010
Testimonial: "Though tride most of advice a very quick and helpful reply, many many thanks to you, regards max."
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Wma44 hotpoint washer. Did a wash as normal and
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
The door locked light will not go on.
If the door locked light is flashing, then in all probability, the main p.c.b board has blown due to a motor fault which caused the fuse to blow in the first case..
If no llight at all, then could be broken door latch or spring. If you pull on the handle and it feels sloppy , then that is where your problem is, it is not very often a door lock fails on one of these m/c's.
Plz rate my solution
Thanks.
Dec 29, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Oct 15, 2008 | Hotpoint WMA13 Front Load Washer
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
