Question about Coffee Makers & Espresso Machines
HOW TO USE A BUSH CMM142
IM WONDERING HOW U ONLY MAKE ESPRESSO IN THIS BUSH MACHINE WITHOUTH THE FILTER ONE RUNS TO??? CAUSE EVERYTIME I TURN IT TO ON BOTH WATER BOILS BUT I ONLY WANT TO MAKE ESPRESSO AND NOT FILTER COFFE
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Fulvio
Posted on Jan 18, 2009
SOURCE: water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
Posted on Jan 07, 2010
  • 15 Answers
SOURCE: I've A Breville 800 esxl espresso machine.When mak...
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Posted on Nov 27, 2010
I need instruction manual for my Bush CF04 coffee machine
http://manualjdk6.exhibitor-news.com/art/bush-cf04-filter-coffee-maker-manual/
Jul 20, 2011 | Coffee Makers & Espresso Machines
Runs slow
There is a quick and inexpensive solution to the problem. Household vinegar. Pour about one cup vinegar into water reservoir, replace filter basket without filter allow it to cycle through. After it has finished brewing, you may repeat with another cup of vinegar. Once you are finished running the cycle with vinegar, fill water reservoir with water and cycle through. Be sure to run water through machine at least twice to rinse out all the sediment and or vinegar. Works everytime my coffee maker starts running slow.
Jun 17, 2010 | Cuisinart DCC-1200 Coffee Maker
When I turn on the machine, instead of allowing me to choose how much coffee I want, it flashes Time and doesnt' allow me to make coffee. what is wrong?
Everytime the mainswitch is turned off you must set the time, there`s no backup battery on the machine, so the time is lost everytime you power down. If you set the time you can program on/off time. To avoid this every day, just use the standbymode.
Jul 25, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Water is dripping out the side of the porta filter
You will have to replace the group gasket, you can also try using a group brush to clean any coffee grounds up there, but you will most likely have to replace the group gasket.
Apr 06, 2009 | Gaggia Evolution Espresso Machine
Water light is flashing but tank is full
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Delonghi EC 140 Espresso Machine
return to store or company..don't open machine or warrenty will be voided
Sep 05, 2007 | DeLonghi EC140 Espresso Machine
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
