Question about RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
I need the impeler part #530047702 - RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
  • Ralph grandinetti Sep 07, 2013
    Where can I order this part and how much #530047702
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
Try White Jones, if they don't have it on hand they can order it for you....
Hope it helps...
Posted on May 13, 2013
I have 2 flotec cyclone pumps. Both need impellers. Where can I get them? I don't need a whole repair kit. Just the impellers.
I believe you can find it at this website.
http://www.pumpagents.com/JabscoPumps/Jabsco-Impeller-Guide.html
Good luck
RJ
Nov 10, 2011 | Flotec 1/2hp Cyclone Pump
I am looking for a kinki waterpump on yanmar diesel engine
Which kind of kinki impeller you need?We have the KINKI BK-0132 and BK-0134
Flexible Rubber Impellers replace KINKI impeller BK 0132 BK0132 Neoprene Flexible Rubber Impellers replace Kinki Impeller BK 0134 Neoprene
I hope which can help you:-)
Best regards from Vera
Flexible Rubber Impellers Mfg Co.,LTD
No.285 Yunshan Rd,National Hi-Tech zone
Ningbo 315040,China
Tel:+86-574-66850926
Fax:+86-574-66850926
Email:sales@flexible-impeller.com
http://www.flexible-impeller.com
Aug 27, 2011 | Computers & Internet
I need to know how to tape the impeller off. i was told that i had to pull the pump apart in order to remove the impeller????
You do not supply much information, but yes, the impeller sits right inside a pump housing, Split the housing and the impeller is the vaned part that is attached to the shaft, the pump rear casing will have remained behind. The should be a nut holding the impeller in place and it may very well be a left hand threaded nut. Remove the nut and the impeller will come off with a little coaxing. Some impellers are press fitted and may need a puller to remove.
Jun 30, 2011 | Garden
I am installing a new water pump impeller and cover. To remove the old impeller, some suggest putting pressure against the kickstarter. I tried and that didn't work, the engine still turns over. Others...
There is a lock ring on inside of impeller inside cover you need to remove that lock ring in order to remove impeller.By just removing little cover exposing water impeller will not let you remove impeller.you need to remove the whole side case to get to lock ring.On most bikes you have to drain oil,coolant and remove case cover.If you google this,it will give you exact instuctions or possibly a you tube vidieo.A picture is worth a thousand words.Good luck....
Feb 06, 2011 | 2005 Yamaha WR 450 F
Dishwasher will not pump water out
The impeller of the pump-out pump siezes OR the impeller siezes because the water seals inhibit it from turning.
Problem well described in Owners Manual.
Yo may need to empty with a bucket initially.
Under the filter plates, there's a plastic access cover to the impeller.
You need to remove 1 Philips Head screw, the cover lifts off, and you can see the impeller, it is about 25mm (1") in diameter.
Remove any foreign material in or around the impeller.
Spin the impeller by hand.... it sometimes feels a little resistant, as though the seals on its shaft are gripping it.... this is OK.
Reassemble and try it out.
Good Luck
Dec 21, 2010 | Bosch SHU9915UC Dishwasher
Need to replace pump Impeller on A.O. Smith Century Centurion Pool & Spa Duty Switchless Pump
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 11, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
Remove the Impeller on the motor of dishwasher
you can acess the impeller, by removing the lower spray arm, ther are 5 torx scrws holding the motor cover down, then from ther ther are 2 additional torx 15 screws covering the pump outlet and impeller housing, the impeller is spring loaded in place.
May 15, 2010 | Dishwashers
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag Logo
82 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
