Question about Car Audio & Video
JVC Radio Every time I turn volume up to 30+ on my radio it messes up and gives me this reading. I reset it and try it again and it does the same thing. Further explained in video. Some advice would be helpful
    New Friend:
  • 38 Answers
It could be going into protection mode. Try turning your gain on your amplifier down and then try going past 30 and see what it does. Or you have too small of speaker wires or remote ect or what not, and you might need to get a bigger gauge wiring kit.
Posted on May 10, 2013
  • 11 Answers
SOURCE: 03 suburban yellow wire won't give power and speakers don't work
Your fuses are most likely out. The thing is, is that if any of those wires touch you can blow out some fuses, that may mess with the odometer, gas, oil and temp readings. More than likely your fuses have busted when you were changing out or even when you ran that wire directly from the battery.
Rixtarick
Hope that i could help you out. If worst came to worst, you would probably just need a continuity tester to see what wires were giving power, after you changed those blown out fuses.
Posted on Mar 30, 2009
bigTROY502
  • 129 Answers
SOURCE: The RSX BOSE radio stopped working.
If you disconnect the bose radio, it loses it's programing.. Needs to be taken to a GM dealer and vin coded. as for the volume knob, it's digital.. if it's not working it wont be a connection issue, it's likely a flaw on the board. The best place to get that fixed is United radio in NY. 1-800-448-0944
Posted on Aug 07, 2009
  • 4930 Answers
SOURCE: astra radio code - i know the code, entered it as
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
(It could take many hours)
Posted on May 30, 2010
jdinse
  • 74 Answers
SOURCE: I lost power to the car's system and the radio set
you would need the code from the dealership that is usually in your owner manual for the the car. If not you would need the radio removed and get the serial# of the radio and provide the dealership with this number and they should be able to provide a code.
Posted on Jun 08, 2010
hch2011
  • 458 Answers
SOURCE: my radio on 1992 Ford Explorer keeps blowing the
Power cables are exposed either at battery area in engine or stereo compartment. Search to acquire and remend an exposed power wires else would blow all fuses.
Posted on Jan 29, 2011
How do I reset the time on my JVC KD-R200 CD RECEIVER/ WMA MP3 PLAYER?
I am not sure about the reset. You can change time. Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
My radio lights are on but no sound, what do I do??
Try to mess with the fade and balance. It's possible you have one or two bad speakers and the radio only has the bad ones getting power.
If you have a remote or can borrow a remote (or have steering wheel controls) try to change the volume with it. Your volume button could be bad on the radio.
Something else you may want to try; first make sure you have your unlock code for the radio! Then remove your radio from the dash. This will take some time but be patient you don't want to break anything. Once out unplug all the wires and wait about 10 min's. This will sometimes reset the radio but if this works it will most likely go back out in due time. This will give you time to get a new radio.
You could try to pull the fuses to the radio instead just make sure you get them all or disconnect the battery for a while. These two may not do anything sense some pcm or ecu have their own battery back up and the radio will use it for it's memory if it can.
Another way to check the speakers is to do a oil lift reset. If I remember right; you can do the reset though the radio and it should chime over the speakers.
Most likely the channels have burnt out and you will need to replace the radio. Stay with an OEM shop ebay.
Apr 30, 2010 | 2003 Chevrolet Impala
I have a 1992 Honda accord have the code from the dealer but can't get the radio to unlock
The radio will only give you 3 attempts.If you get out of sequence or just fiddled too many times, Either pull the "backup" fuse under the hood,or disconnect the battery for at least 5 mins. then try the code again. If you mess up just press any number SLOWLY until it reads "error" the try again
Mar 29, 2010 | 1992 Honda Accord
Satellite receiver not responding
reset the receiver again and try if its responding again
Feb 06, 2009 | JVC SIRIUS Satellite Radio Interface for...
Volume won't go past 30
Turn on. Set volume to 00. Press & hold the volume knob for about 10 sec., until you hear a beep. Then turn volume up to the maximum that you would ever want, and then press the volume button again. It is now set.
Feb 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Honda radio codes
turn the radio off push preset buttons 1 &6 while holding these buttons turn on the radio the serial# will come up call the dealer with this # they should give you the radio code if you have a problem write back i can get it for you if you have error on the radio then disconnect the battery cable neg for aprx. 30 seconds reconnect the enter the code using your preset buttons
Aug 01, 2008 | 2007 Honda CR-V
Changing the time on my radio
push the sel botton for 5 second, with the volume --ff & rew botton select wath do you want.
Jul 21, 2008 | JVC AM FM CD DET FACE CAR STEREO
Jvc sirus and ipod issues
I am having exactly the same problems. No sirius and ipod has to be turned up very loud to hear at all. The problem appeared suddenly friday night with no movement of accessories. It was working when I turned it off and wasn't when I turned it on a few hours later. I have checked connections and reset unit with no success.
Oct 02, 2007 | JVC KD-HDR1 CD Player
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
