Question about Toro Garden
Toro 14 38 hxl
14-38XHL NO CRANK WITH KEY SWITCH...NEW BATTERY.....JUMPED STRAIGHT TO STARTER AND......ERR....ERRR...ENGAGE BUT NO CRANK.....LOSSENED...TIGHTENED....ALL CONNECTIONS.....WORKED WHEN PARKED BEFORE WINTER....THIS IS BEING GIVEN TO ME...AND I WOULD LIKE TO GET IT HOME! IT WONT DISENGAGE WHEELS TO ROLL...SO WHAT TO DO?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toro Master
  • 1,917 Answers
If it has flat tires your thinkig its not disengaging but it is it does not want to roll on flat tires shove it back and forth till it rolls once you have tranny disengaged nothing holds it that should get you home then we can work on the rest
Posted on Jun 07, 2014
SOURCE: Won't crank--some kind of electrical problem
Disconnect the (battery) starter cable and check with a multimeter the continuity of the starter relay thru the relay terminals which connect the battery to the starter (key will have to be turned to start) -- if you get continuity, it's likely not the relay, but I'm with you, it sure sounds like the relay (solenoid).
P.S. Running a starter directly off a charger is a good way to burn up a charger.
Posted on Apr 28, 2009
  • 4 Answers
SOURCE: The front wheels on my lawn mower have locked
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
  • 59 Answers
SOURCE: mower won't start
sounds like the ground cable is bad
Posted on Jun 26, 2009
  • 202 Answers
SOURCE: Toro 6.5 self propelled Mower - Self Propell won't engage
see if the lever going to the gearbox is cracked or broken. there is a gear inside the box that has a pin going thru the shaft that may have broken but usually it is external. these mowers have a plastic lever to put the transmission lever in gear if the cable is overtightened they wont hold up.if it cracks it leaves practially no tension on the engagment system
Posted on Jul 17, 2009
  • 62 Answers
SOURCE: cub cadet 2166 won't start. replaced switch.
SOUND LIKE A LOW VOLTAGE PROBLEM. MAKE SURE YOUR BATTERY IS GOOD
Posted on Sep 25, 2009
I have a 445777/0129-E1 engine that won't crank when I turn the ignition key. What should I check next?
The click will be the fuel switch on the carb that opens when the ignition is switched on. When you jumped the battery to the starter did you have the ignition on? If not it won't be getting fuel. If you find the wire that goes from the ignition switch to the starter solenoid (usually mounted on or near the starter motor) and connect the switch end of this to the battery does this crank the engine over? If so then the ignition switch will probably be faulty or have dirty contacts. If not then I'd suspect the starter solenoid.
Sep 21, 2015 | Sears Craftsman 46 in Mulching Tractor...
I replace a new starter on 2008 Saturn suv 2.4 4 cylinder still doesn't crank
Sounds like a security system issue. Using the key fob to lock and unlock the doors will usually reset the system. You may have to do this procedure a couple of times and see if it works
Jul 13, 2015 | 2008 Saturn VUE
Car won't engage starter
At the starter relay, you have two red or purple wires, one goes to the starter and the other comes from a 30amp fuseable link. Is that fuseable link circuit hot ?
From the key switch, power goes thru the alarm relay, then the clutch safety switch or automatic selector switch, then to the starter relay. The fourth wire on the starter relay is a ground.
You should be able to put power to the starter relay on the white or yellow wire coming from the safety switch to make the relay engage.
My guess is something wrong with the alarm system.
Mar 02, 2014 | 2004 Hyundai Tiburon
Won't crank over
The solenoid on the remanufactured starter may be defective. Also, sometimes it is necessary to shim a solenoid to get it to engage the ring gear properly.
Dec 14, 2013 | 2000 Ford Expedition
No start, no crank
If the starter won't engage, you can't crank the engine. You would only hear the starter operating freely. The replacement starter may have to be shimmed to fully engage the ring gear. Also, did you verify that the ring gear is OK?
Nov 21, 2013 | 2004 Ford F150
When i try to start the riding mower will only crank once.....toro 16-hxl will crank once, then nothing
Make sure your battery is in good condition first. Then if your machine is an OHV you might want check the intake and exhaust clearance. Go to smalleng.com and watch video they have a great tutorial on this subject. Good Luck...
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
All comes on when key is turned on, starter will not engage when key turned to position. new starter, new battery, starter attempts to start car when jumped at starter relay 87 w/key on. car had started,...
Does the car have a factory security system? it may have a starter kill on it.
also check for voltage at the starter solenoid while someone holds the key to start position, you could have a faulty ignition switch.
the engine light stays on when the key is on until engine starts.
Sep 10, 2011 | 2004 Chrysler Sebring
Garden Logo
255 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
