Question about VIDAR Systems VIDAR TruScan Atlas
Bulb replacement vidar - VIDAR Systems VIDAR TruScan Atlas
Replace the lamp of 4230i
Nabil, Check the attached links how to replace lamp.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Contex HD5450 User Manual Replacing The Scanner Lamp unit
Contex FLEX50i User Manual Replacing The Scanner Lamp unit
. ContexParts buy parts and accessories for Contex Vidar and Ideal scanners...
Mar 07, 2016 | Contex H42-6799G513 - Hd Ultra 4230
Can the vidar truscan p-88 4019 do color?
This scanner does black&white and gray-scale scanning but not color.
I hope this helps.
Aug 31, 2010 | VIDAR Systems VIDAR TruScan Select Pro
What is the RAm on the DEll Pentium 4 computer? Will it handle autocad 2008?
plz right click on my computer then click on properties then general tab you can view your ram capacity
Nov 11, 2009 | VIDAR Systems SELECT P36
I don't have driver for truscan titan yet
hi,
hope this can help you for your truscan titan drivers update at the link below.
http://support.vidar.com/default.htm
Nov 28, 2008 | VIDAR Systems VIDAR TruScan Titan II
Software driver for vidar true scan select plus
Try this:
1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and
download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel->
System->Hardware Tab->Device Manager) and select the Driver tab within
the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from
autocd.exe).
May 09, 2008 | Office Equipment & Supplies
Select P36 not complete self diagnostic
I had same problem. Upgrading the firmware on the scanner fixed it all.
Mar 10, 2008 | VIDAR Systems SELECT P36
Minolta Dimage Scan Dual ll
Hello ! I try to use many difrent driver in difrent mod. eks:95,98,2000,xp
The best was 98,butt it still stops when the scanning starts.
Solution for my problem.......Vuescan from Hamrick.com
Mvh
Vidar
Norway
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Fluffs on my glases
Use a suction pad to lift the glass off of the magnetic plate and clean the underside.
Jan 25, 2008 | VIDAR Systems VIDAR TruScan Titan II Plus
Vidar select Pro Bulb? Blown out?
An E-mail to the makers web site will tell you whether parts are available for self fit or you need the expensive repair dude.
Nov 21, 2007 | VIDAR Systems VIDAR TruScan Select Pro
VIDAR Systems VIDAR TruScan Atlas Logo
32 people viewed this question
Top VIDAR Systems Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
