Question about Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P monitor exhibits intermittent "posterization" effect
My Sony SDM-HS74P monitor has been exhibiting intermittent "posterization" effects which have progressively gotten longer and worse. Switching the panels front brightness setting to "LOW" seems to minimize the effect but there are still many light pixels. The "MIDDLE" "HIGH" or "USER" settings do not minimize the problem. Any suggestions as to the problem/correction would be appreciated. Thanks
5 Suggested Answers
najah
  • 180 Answers
SOURCE: MY SONY SDM-HS74P
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Posted on Apr 08, 2008
  • 9 Answers
SOURCE: Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Posted on May 17, 2009
SOURCE: My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
Posted on Jan 04, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an sdm hs74p monitor that repeatedly blacks
You may not have problem with the caps, but check them out any way. You should get good caps such as PANASONIC FM or FC series from DIGIKEY.COM
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Posted on Apr 04, 2010
Icons and text exhibit a right-handed black and white dithering or noisy shading effect. This gets increasingly bad as windows are opened and closed. It almost looks like a RFI/EMI radiation problem but...
If the monitor displays a similar effect on the monitor's own display, the colour ajustment or no signal display then the answer is most likely yes. A good tech guy may be able to fix the problem but it's going to cost almost the price of a smaller screen, similar to what you have, anyway. My suggestion is to just grab yourself a new monitor.
May 07, 2011 | Balance CM2019 19" LCD Monitor
Dec 13, 2009 | Sony SDM-HS74P/S 17" LCD Monitor
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
MY SONY SDM-HS74P
Apr 06, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Sony SDM-HS74P/S 17" LCD Monitor Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
