Question about Sony Cameras
Service centre will you give me a clear note about metering mode
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
What model Sony digital camera?
Posted on May 09, 2013
Testimonial: "cyber-shot/DSC-W310 "
After changing overflow container what's next is there an error I need to clear?
sir does the screen display M -2 code ? I assume you are talking about the WASTE Toner Container??? Then go service mode and clear the counter and reset to 240k . Under Consumables
Service mode = utility, meter count, stop00 stop01 consumable waste toner clear and reset to 240K
Dec 18, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
My Dialta Di2011 gives me an error code cof32 service call. What are the likely problems?
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
Feb 07, 2013 | Konica Minolta Office Equipment & Supplies
Error E005-have replaced cleaning How do I get in
You enter the service mode by pressing the push switch inside the inner front cover by the meter. there's a small hole, insert an allen key or paperclip and press gently. A "$" will appear in the display when the service mode has been activated. Once in the service mode press * then 4 then * to enter the function mode. Use the > key to advance to the second selection press 1 then * to clear the error and power cycle the copier. If the web has been installed correctly and the web sensor is ok. The error should clear after cycling power.
Aug 25, 2011 | Canon NP 6050 Copier
My canon iR2016 has a system error E001
the e001 is error for temperature rise by main thermistor. If the termistor OK and doesn't need to be replaced you can clear the error in service mode. If clear doesnt helps, you need to change the fixing film assy.
Clearing error:
Press the User mode key, 2key, 8key,
User mode key sequentially
now you are in service mode, by arrow right, select #CLEAR, press OK, choose ERR and OK.
Also you can try with same procedure but instead ERR choose ALL. NOTE: under clear ALL, you delete all user data and restors the copier on factory settings.
Hope that helps!
Aug 25, 2011 | Canon Office Equipment & Supplies
Canon ir7105 finisher unit is not working..!
The finnisher is only in disable by a a disable funcktion that switch the finnisher off.It just need a reset in the service mode.I am not alowed to give service info on the net.Ask your local service centre to clear the funcktion for you.You dont have to replace the finnisher.This is normally a paperjam or a opstical that prevented the trays to move up and down.Then the finnisher go to disable funcktion
Thanks for you support
Dec 12, 2009 | Canon imageRUNNER C3200 Copier
Sony ericson T650i phone disply is not working
If I understand your post correctly you say the phone is not very old - you said it began to give trouble after only a month. Clearly the service centre gave bad advice about a phone clearly still under warranty.
The service centre claiming they can't fix it means nothing. Your contract is with the retailer you bought it from and no one else. The phone is faulty and so it is the responsibility of that retailer to either repair the phone or replace it free of charge.
If you have problems there could be a department of your local government that will help and you certainly should contact Sony-Ericsson directly via email AND recorded delivery letter and tell them of your problems and disappointment. Don't hesitate to name the retailer and the two service centres.
Mar 05, 2017 | Sony Ericsson T650i Cellular Phone
LG shine 3G service
Here are the steps:
Enter 277634#*# Scroll down to #5 modem setting and click OK Scroll down to #2 network mode and click OK Click OK again on #1 network mode Scroll down to #2, 2g only, and click OK ***SEE NOTE BELOW*** Press clear until you are out of all menus. Power the phone off, wait 15 sec, power on. ***NOTE*** When changing back to 3g, select dual mode in this step.
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Spot Meter on Canon Rebel XT?
there's a metering mode setting.
from the manual:
(metering mode on first menu1)
evaluative metering - standard setting, takes account off all areas of scene.
Partial metering - effective when background is much brighter than the subject due to backlighting etc.
Centre weighted average metering - the metering is weighted at the centre then averaged for entire scene.
pressing the right hand button of the two little ones top right corner of camera brings up display on lcd, using thumb wheel you can select where the metering takes place. in the viewfinder the display lights a red dot for areas selected.
Try these settings to see if this helps in your situation.
Nov 12, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
14 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
