Question about Jet 3 Ultra Power Chair
I replaced the battery charger with a quest charger, chair now charges but wont function i guess because of the inhibit feature how can i fix this
    Sergeant:
  • 317 Answers
A few things to consider: A blown charger fuse can cause the charger inhibit to activate. Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Posted on May 15, 2013
SOURCE: Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Posted on Nov 10, 2008
  • 16 Answers
SOURCE: new battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Posted on Mar 06, 2009
dromtonpa
  • 40 Answers
SOURCE: Wheel chair will not stayed charged.
Also sounds like your dealer is not on the level.
Posted on Mar 26, 2009
dromtonpa
  • 40 Answers
SOURCE: jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Posted on Apr 10, 2009
  • 177 Answers
SOURCE: My chair is not charging. We are getting 34 volts
Hi. A voltage of 34 volts is way to high. Most chargers are limited to about 28.5 volts. You will quickly dry out your batteries at 34 volts. I would say your charger is very faulty.
You have probably already destroyed your batteries at that charge rate.
Are the batteries new or a couple of years old.
I serviced a machine last year, that, according to the owner, had been through 6 sets of batteries in 4 years. His charger had the same problem as yours.
Good luck. Neil.
Posted on Jun 22, 2010
When i turn on my chair it reads controller and does nothing but flash controller
If this is when the charger is plugged into the chair, the chair goes into inhibited mode so you cant drive away towing the charger with you. A safety feature.
Jun 06, 2015 | Invacare Invacre Battery Charger...
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Wont turn on light just flash back and forth on speed setting
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Sep 25, 2010 | Pride Mobility Products New Pride Mobility...
Pride victory and pride jazzy will not charge the batteries and when plugged in. The inhibit function seems to not be working either.
Bad charger port on joystick only fix is to replace joystick or if it has a seperate charger port underneath the jostick that has to be replaced
Aug 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jet 2 power chair with with 3 red and 3 yellow lights flashing. Batteries checked ok under load, all connections have been checked. I moved the chair and it would not move again. Just that quick.
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
106 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
