Question about Refrigerators
Amana ABC2037DES Bottom Freezer Refrigerator
The water spigot freezes. Most times, when the dispenser button is pushed, the dispenser pushes out a small particle of ice. This morning, it took a few pushes of the button to free the line for water flow. Why is this?
  • Refrigerators Master
  • 4,654 Answers
Amana ABC2037DES Bottom Freezer Refrigerator - 3e0fb770-1a2b-4585-8792-01c3cc3b036a.jpgc051bc82-adf9-4252-bf89-7a54e5ee5bae.jpgYour fresh food section may be too cold and causing this problem by freezing the water reservoir and sections of the
water line going to dispenser. If you cannot set the temperature a little warmer this can be caused by a defective W10196393 Auto Damper This problem also can be caused by the fresh food section 12002355 Thermistor The thermistor is a electronic way of measuring temperatures in fresh food section, freezer and ice maker also have thermistors.
Here is a ABC2037DES Tech Sheet with the diagnostic's
for thermistor's and the auto damper, I will help you if you like so please let me know if you have questions, Thanks Sea Breeze
Posted on May 10, 2013
  • John Tripp
    John Tripp May 10, 2013
    Here is the ABC2037DES Tech Sheet http://appliance911seabreeze.com/ABC2037...
  • Mike Kliman May 11, 2013
    Thanks for your help. I've made some adjustments and now let's see what happens. Thanks again, Mike
  • 159 Answers
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
aasc
  • 1606 Answers
SOURCE: After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Posted on Jul 19, 2009
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser stopped working, freezer temp down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Dec 17, 2009 | Amana Side by Side 20.6 cu. ft. Cabinet...
Where are the condenser fran coils on the Amana ABC2037DES?
most modern units the fan coils are underneath the unit normally acessed by removing the grill underneath the freezer door the coils are normally cleaned with a long brush that looks like a cats tail but can also use a long handled bottle brush just be gentle the coils are metal but do not want to jab with
anything sharp
Dec 13, 2009 | Amana ABC2037DES Stainless Steel Bottom...
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Water dispenser
Usually when this problem occurs, i just keep pushing the button and it will after a minute come through. This time, i had to remove the water filter and empty the water out, put the filter back in and pushed the button til it dripped, then a trickle and then it was back to normal.
Feb 22, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
No water thru door
I would try putting on the light at the dispenser. It worked for me but took almost 24 hours to work. I am now keeping the light on all the time. Simple solution to try. My ice was working when the water was not coming out.
Feb 06, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
