Question about GE WBVH6240F Front Load Washer
Washer does not wash or spin
When the washer goes into spin or cycle you hear a low hum and then it sounds like a breaker opening up and panel lights go out.
  • Anonymous Jun 08, 2008
    my washer will not drain/spin. the drum does turn, but the pump blade
    will not rotate and washer just times out and shuts off. I let it sit
    for a week - power off (but still plugged in) and the pump was burning
    hot to the touch. Checked with volt meter, pump is getting proper
    voltage, but will not rotate. Standpipe is good, filter cleaned out.
    Dismantled as much of pump as possible and inspected for blockage
    inside the pump - but it's clean. Washer is 2 years old. Should I just
    replace the pump or get repairman out to check electrical?
    Thank you for your help!
    SuzyCue
    Novelist:
    Champion:
  • 244 Answers
Does the drum turn at all if not more than likely the carbon brushes which is situated in your motor these must be about 1inche long
Posted on Aug 12, 2007
SOURCE:
I started my washer and I worked just fine then it went into an extra rinse cycle and now it won't drain or spin the door switch works I can hear it click and then a low humming sound
Turn power off, then set the machine to a spin cycle, you may need to do this several times before the door will open. Hope this helps
Oct 08, 2015 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Will not spin
The humming sound is most likely the pump running. Try this: Open the front panel by using a putty knife to push in the clips (2) at the seam where the front panel meets the washers top. With the washer in the spin cycle (you hear just the humming) pull the little hose off the left side of the outer tub, near the bottom. The washer will most likely begin to spin immedeately. If it does, this would indicate that the hose and the nipple it connects to need to be cleaned out. Gunk builds up there some times and then the air cannot escape back out, so the washer thinks it is still full of water, and thus will not spin. After cleaning those out, replace the hose with the tub empty of water. If the washer did not spin after pulling the hose, check the lid switch.
Mar 29, 2010 | GE WBSR3140DW Top Load Washer
My washer/dryer doesnt spin after going through the wash cycle, during the supposed spin cycle you could hear a humming sound and when it stops there is water in the drum and you can open the door. Is this...
If you can hear a rumbling sound from the drum, then I would say that the main drum bearings have failed.
This is a major repair job, and not one I would recommmend you undertake yourself. as it involves a complete strip down of washer, and the cost is cosiderable.
Probably better to purchase a new washer.
Good luck.
Jan 06, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Frigidaire GLTF2940ES0 won't pump or spin
Sounds like a water valve solenoid. The hot and cold water is controlled by solenoids that open and close. Try running just the hot and just the cold. If one or the other works, then the proble,m is a bad solenoid valve
May 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Trouble with the spin cyle.
Bad motor. Easy to replace. Worth the effort.
To find out how, click HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 04, 2009 | Kenmore 24982 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Wash goes silent at the rinse and spin cycle
if the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Mar 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LGR7648KQ1 top loader washer
Hi It appears that- You have a clogged water pump inlet filter. Normally located at the bottom of the machine there should be a 1"-2" disk that you need to rotate half turn to release. Be aware that a large quantity of water is likely to drain when you open it. Good luck
Sep 07, 2007 | Washing Machines
GE WBVH6240F Front Load Washer Logo
60 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
