Question about Binks Model 7 Conventional Suction Feed Spray Gun, 1.8mm Tip
Gun spray paint
Intermittent paint spray from a binks model 7 paint gun.
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
  • 760 Answers
SOURCE: No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Posted on Jun 30, 2010
SOURCE: i am trying to find a manual for a binks 2001
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Posted on Dec 08, 2010
  • 15 Answers
SOURCE: my binks 18 spray gun squarts paint from the hole
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Posted on Feb 28, 2011
  • 14 Answers
SOURCE: I need a users manual for a binks model 15 spray
Here you can find a manual: http://www.tpub.com/content/automotiveaccessories/TM-9-4940-507-14-P/TM-9-4940-507-14-P0006.htm
Michael
info@bsc-teknik.com ' www.bsc-teknik.com
Posted on Jun 21, 2011
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
Air feed through gun with out touching the gun
take and screw out your top knob which is your fan control and clean it and also make sure none of the rubbers and seals are cracked, it might be possibly out of adj, but probably just dirty with old paint, clean it out really well with pipe cleaners or brush with paint laquer thinner
Sep 16, 2011 | Binks 54-1341 Air Valve Assembly For 7...
What is the best setting for spraying dupont imron urathane enamel with the 92s activator
because you used activator so the paint will be dried fast, therefore u probably want to paint it in a fast pace. set inlet air pressure at 2 bar, fluid control all the way until the trigger is loose. fan all the way open. paint it closer then normal and move fast.....i dont use activator but that's probably how i would do.
Sep 05, 2011 | Binks Model 7 Conventional Suction Feed...
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
Delivers the product but has a pulsating spray Binks Model 7
There is actually very little in the gun in the way of parts. The outer front nozzle unscrews, then the inner nozzle (you need a thin open-end wrench). The fluid and air controls unscrew from the back with loose springs. The fluid needle pushes out the back and the air valve unscrews from the front side of the handle (you may need to remove the trigger to get the valve out). The only critical area is outer and inner passages of the two front components. Soak the entire gun and parts in gun cleaner for an hour or two, then blow everything clean with compressed air. Lightly lube the trigger bearing, fluid needle (not the thin part), and air valve assembly. Put a little light grease on the threads of the two controls and their springs. Don't oil anything around the nozzle. Hopefully, you found a wad of paint in the gun body after soaking it. After reassembly, check the air flow first which should not pulsate. If it does, check the air line with a blow gun--does it pulsate? Check the regulator, hose, and air filter if it does. If the air delivery is good but the gun still pulsates while painting, check the paint supply system. Hope this saves the gun--I've had a Binks gun for many years and it was well used before I got it.
Oct 08, 2009 | Binks Model 7 Conventional Suction Feed...
Binks  Model 7 Conventional Suction Feed Spray Gun, 1.8mm Tip Logo
29 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
john h
russ davis
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
