Question about Sony KP-48S75 48" Rear Projection Television
Green haze/shadowing on left third of tv
I was given this tv, and the left 1/3 of it has a green haze and shadowing. I'm not sure what this is from but my X-Box 360 begs for it to be fixed. So if you can give a clue to repair this problem I would deeply appreciate it.
SOUNDS LIKE YOR GREEN CRT NEEDS TO BE REPLACED OR PERHAPS A SMOOTHING CAPACITOR ON YOUR 200V LINE IS OPEN CIRCUIT,PERHAPS YOUR CONVERGENCE ADJUSTMENTS NEED TO BE RESET.
Posted on Aug 14, 2007
SOURCE:
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
3" shadow on left side of screen
watch for speakers being to close to the tv. if a speaker has a big magnet on the back of it, it will cause it to have the shadow and then it will turn green. so make sure there is nothing with a magnet close to the tv because it will ruin the tube on the tv.
Apr 10, 2012 | Panasonic TCP50S2 50 in. TV
My awa led lcd tv has a green haze/shadow
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Jun 06, 2011 | Vizio L6 20.1 in. HD-Ready LCD Television
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Aug 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Philips PET824; the left third of the screen is Green
Call Philips to see if you are in warranty if the reset fails
Jun 12, 2008 | Philips DVP5140 DVD Player
Green Shadow
The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
Dec 31, 2007 | Philips 50P8341 50" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Sony KP-48S75 48" Rear Projection Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
