Tajima embroidery tech support
I have an error code 3C1 and I turned off the machine and restarted it but it did not go away. What else should I do?
5 Suggested Answers
Saigua
  • 981 Answers
SOURCE: will embroidery designs from Dakota
 Why wouldn't you ask Dakota collectibles?  Moreover, why would you care as long as you can find free software for your PC that converts designs from format to format?
Posted on Jul 31, 2008
jpack76645
  • 23 Answers
SOURCE: what is a 211 error code on a tajima 2 head emb
A 211 is generally caused by the degree wheel not resting in the "red" zone. This zone indicates the machine is in a ready state to start or shift. Look at the degree wheel and manually move it to the zone (around 100-110 degrees). If this doesn't work it will need repaired. It usually takes 1-3 hours depending on what is involved.
Posted on Dec 01, 2009
SOURCE: Tajima embroidery machine error code 316
it sounds like their is a problem with the electronics of the
embroidery machine and the machine needs to be checked.
Posted on Dec 19, 2012
  • 470 Answers
SOURCE: how do I fix error code 2CF of Tajima embroidery machine for TFSN,TFKN,TFGN.
2CF - An immediate stop came in from an external. Check the external device or the connection to the external device.
device TMLG, connector joint 16 JH08
Check for a loose connection in any external device like a keyboard or card reader.
Posted on Feb 06, 2015
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Sep 28, 2017 | Sewing Machines
How do I fix error code 2CF of Tajima embroidery machine for TFSN,TFKN,TFGN.
Feb 06, 2015 | Sewing Machines
How do I fix error code BC1 on Tajima Embroidery Machine when there are designs on the flashdrive that did work yesterday
The format of your program may have different formats that will work for Brother but not Tajima. The extension of the program is the key to the one to use. You will notice a program name that is the very same but the extension is different. Your program can't be found if you use the wrong extension. Use other design extension or you may need to register the program.
Nov 18, 2014 | Sewing Machines
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
Did you recently break a needle while using the embroidery machine? Check for foreign objects (like part of a broken needle) in the rotary hook. Then press Set to reset the machine. Remember to turn off the machine and then unplug it before doing any maintenance. If there are no obvious foreign objects, the rotary hook may have been damaged by a bent needle. It may need to be replaced.
I hope this helps.
Jun 04, 2013 | Computers & Internet
Dec 19, 2012 | Sewing Machines
96 people viewed this question
jasbo
jasbo
