Question about Bernina Sewing Machines
The needle is getting stuck in the fabric on my Bernina 1008.
I first thought it was old needle. Replaced the needle. Happened again. Thought is was the fabric so switched to light fabric. Happened again. Took apart - cleaned and oiled bobbin area. Still not fixed. You can feel the needle sticking just while turning hand wheel. Turning handwheel only and with no fabric you can hear the needle clicking against bobbin case. Help??? Service seems very pricey!
  • Bernina Master
  • 11,228 Answers
Service is a good thing: 1) if it fixes your problem, 2) if it prevents a more expensive repair rather than allowing the problem to continue, and 3) if the general checkup helps keep your machine running longer. You spent a lot of money for your fine Bernina, so spending a $100 every once in awhile pays off...compare it to buying a new car and never changing the oil. Sounds like your machine is out of time and needs service, but you can also get it cleaned, oiled, and adjusted at the same time.
Posted on Jul 30, 2017
    New Friend:
Sounds like it needs to be serviced. Needle should NOT be hitting the bobbin case.
Since you don't want to have it serviced, you might check to make sure the bobbin case is inserted correctly and that the bobbin rotates clockwise as you are looking directly at it in the case. Also, is you needle compatible with the fabric?
snakehead
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
SOURCE: Fabric won't advance, bobbin case not turning, feed dogs not moving properly
It's a Singer 5830C -- schooling machine. It's crappy. I'm guessing that a new machine is my best option. For the time being, I'm using my mother-in-law's old metal Nelco.
Posted on Jul 26, 2008
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
HansPP
  • 2510 Answers
SOURCE: my kenmore is about 30yrs
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Posted on Feb 25, 2011
SOURCE: singer 7430 bobbin case clicking sound
it's possible that the bobbin case did not get inserted correctly
or it's also possible that the bobbin case needs to be replaced, I've had to replace the bobbin case on one machine.
Posted on May 30, 2012
My bobbin case jumps out while I am sewing on my bernina 1008.
it sounds like the bobbin case needs to be replaced, have you cleaned under the needle plate & bobbin area for lint & loose threads
I also would suggest to take the machine to a different sewing machine repair shop.
Mar 05, 2012 | Bernina 1008
When I was sewing I stopped the machine to adjust the fabric and pushed on the petal to go again and nothing happened. no sound nothing. I called the bernina store and all they would say is bring it...
Check the simple things like making sure the plug is fully in the control and machine,failing that it will be a shop repair for Bernina
Mar 09, 2010 | Bernina 1008
Needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Mar 23, 2009 | Bernina 1008
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Jan 08, 2009 | Bernina 1008
Sewing Machines Logo
37 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
