Question about Dell Inspiron Computers & Internet
AC Adapter Cord
Is there a way to repair the ac adapter cord for a Dell Inspiron, 13series if the tip has a crack in the wire just below?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Don't take hassle check on eBay it cost pound 4.50
If you fixed it doing here and there and wouldn't give accurate voltage sooner or later you will lose your laptop
Now if you want to repair you need
Soldering iron
Soldering paste
Soldering Wire
Multimeter to check component Trouble
Posted on May 12, 2013
SOURCE: AC Adapter Light Going on and off
This happened to me as well. I did some research online and found that it is a common complaint for the AC adapters that come with these laptops. Basically, the wiring is very fragile, and the adapters only tend to last a year or two. Unfortunately, you will probably need to buy a new adapter.
Posted on Sep 26, 2007
  • 3940 Answers
SOURCE: AC adapter not recognized
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
Check the inside of the connector, since it is new, you can call Dell 800-624-9896 for a replacement adapter.
Posted on Sep 14, 2008
  • 116 Answers
SOURCE: My AC adapter cord, for
Is the flashing orange light flashes quickly or slowly?
Posted on Dec 13, 2008
cheap to fix
  • 404 Answers
SOURCE: problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Posted on Mar 02, 2009
  • 58 Answers
SOURCE: Gateway laptop AC adapter not working
Fixable? Maybe
Sounds like a problem with the power jack on the Motherboard. If so, it is possible to remove the board and replace the jack but this requires soldering skills and is probably not something the average person would want to try.
You might try another adapter to be sure but if it is a motherboard problem the best solution is probably to junk it and buy a new laptop.
Posted on Mar 14, 2009
Polarity
As long as you buy a genuine Dell AC adapter, it will be find.
Do not buy a 3rd party AC adapter.
I have bought at least a dozen Dell AC adapters on eBay. Just make sure the photo shows a genuine Dell.
http://www.ebay.co.uk/itm/Original-OEM-Dell-Inspiron-Mini-10v-Battery-Charger-Power-Supply-Cord-19V-30W-/190678344193
Apr 15, 2014 | Dell Inspiron Mini 10 Notebook
Battery light blinking orange once, then green twice
LOL, It means whoever sold you that Power Cord probably sold you one with the interchangeable end that can plug into any laptop. If it's not the interchangeable end type, they sold you one that is not compatible with your laptop. Get rid of it in a hurry before it burn out your motherboard. You my friend need to get on ebay and purchase a power cord designed specifically just for an Dell Inspiron 1525. All you need to search for on ebay is Dell Inspiron 1525 AC Adapter. They probably cost less than $10
Mar 21, 2012 | Dell Inspiron 1525 Notebook
Will the power cord for the Dell Inspiron 1501 fit the Vostro 1500?
AC adapter for both systems belong to D-Family 65 W lead-free AC adapter So you can use the Ac adadpter Note :- The Vostro 1500 discrete version requires the 90 W AC adapter. Without it, you will receive an error message indicating the wrong AC adapter type, the CPU speed will downgrade, and the battery will not charge.
Dec 21, 2009 | Dell Inspiron 1501 Notebook
I have had problems finding a power cord that works. The original cord died and replacements give eroors
If you are not using a Dell Branded power cord, the system will give an error due to non-Dell AC adapters do not have the sensing circuit needed for the system to ID the adapter.
If you are using Dell Branded replacement AC adapters, then you most likely have a bad power connector on the motherboard.
Dec 19, 2009 | Dell Inspiron 1545 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Power cord for computer
Looks like you have some issues with the port on the motherboard where the AC adapter is plugged in. Try another AC Adapter cord in, if still the same, then call up Dell to have the motherboard replaced.
Sep 23, 2008 | Dell Inspiron 6000 Notebook
Battery not charging
There is a "sensing" circuit that tells the system the wattage of the AC adapter. If that connection is damaged, the battery charger will not operate.
Most likely, you'll need new, 90 watt, ac adapter.
You shoujld be able to get a replacement for under $30
http://shop.ebay.com/items/_W0QQ_fromZR46?_nkw=inspiron+6400+ac+adapter&_fromfsb=0&_trksid=m270.l1313
Aug 23, 2008 | Dell Inspiron E1505 Notebook
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
Sep 26, 2007 | Dell Inspiron 9200 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
