Question about ASUS Transformer BLUE TF300TG 3G 32GB TF300 DOCK Bundle
Transformer ticking Mic is not working
How do I check to see if my Mic is working on my ASUS10 tablet
Just get a simple recorder app, run the app and do a test record, if the mic works you will find out.
May 04, 2017 | Tablets & eReaders
Samsung Galaxy S 10.1 Tablet. Mic won't work on Skype or on videos.
You need to go into settings and turn on Your mic, I would say it has been turned off!
Apr 03, 2017 | Samsung Galaxy Tab Tablet PC
Microphone on my iPad 3 with ios8 not working
Try recording using the voice memo to check the mic if you can then mic is working if not then either downgrade your ipsw to the previous firmware if you are sure it stopped working right after the software upgrade or replace the mic
Mar 07, 2015 | Apple iPad 32 GB WiFi Tablet PC
Nothing happens when I rub my mouse keyboard on my Asus Transformer T100. How do I get it to be visible
Ok I have been thinking about your problem. How long did you actually charge your Asus Transformer?
You might need to charge it about 8 hours minimum to get it to work efficiently. Try that and see what happens.
Jan 05, 2015 | ASUS Transformer Book T100
Static noise
Try connecting an external mic while recording. If it works fine, there may be a probem with your mic
Dec 28, 2013 | Samsung Series 7 Slate Pc Tablet Windows 7...
Hisense sero 7 lite
I am having problems with my mic from my Hisense Sero 7 LT because I try to talk and it somehow isn't working where do I find the Mic settings on the tablet
Jul 29, 2013 | Tablets & eReaders
Nexus 7 tablet mic doesn't work in portrait mode
The microphone for the nexus 7 is a small hole on the right hand side of the tablet, just below the volume button. Make sure your hand and any cases you're using aren't covering this when you're trying to do a voice search.
Apr 10, 2013 | Google Nexus 7
Turn on mic
I read the question and i suggest that if the notebook has inbuilt microphone then the mic is already enabled if u have installed the proper drivers but if u plug in external mic then check the pin and socket of microphone. if this does not work go to control panel and then sound and then check the microphone
Jan 23, 2008 | Acer TravelMate C110 Tablet PC
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
ASUS Transformer BLUE TF300TG 3G 32GB TF300 DOCK Bundle Logo
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
