Question about Fellowes PS60C-2 Shredder
Parts Is there a a larger receptacle that will fit this shredder. I have to empty it too frequently
Main Gear for DS-12CS Shredder
Fixya is unable to identify parts sources.
Jan 23, 2018 | Miscellaneous
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Where can I order custom paper?
You can order it any shop.You can use online shop too like amazon.Its easy to get your thing on your home.I can tell you a provider which is take order.Here is it http://www.poweredessays.com/. Hope you will get what you want.
Dec 04, 2013 | Fellowes Products - Powershred Shredder...
It just stopped working, power light not on. Is my shredder dead? It didn't jam up. Just tried to turn it on one morning and it wouldn't turn on.
My wife put a plastic bag in the basket to catch the shred.
This will block the power switch on the back - bottom -corner of the shredder. The switch fits into slots on the waste receptacle.
Mar 08, 2013 | Tech Solution TS-4500 Shredder
Shred care paper shredder model# tq81b . stripped gear inside shredder,where can i find?
Many people come here looking for parts for their shredders...
The bottom line is that there are no parts available for most shredders, unless they are high end commercial shredders. They are made to be disposable....
Sorry but parts are not available...
heatman101
May 20, 2011 | OfficeMax 0M96431 Shredder
The bin on my royal cross cut paper shredder will not open . It is full and needs to be emptied. It seems to be stuck near the top. If I pull any harder I am afraid the hard plastic will crack.
Yes it is probably "over-full".... you will just have to try to somehow get it open a little and start to fish out the paper without breaking the waste bin....it has to be emptied more frequently, there is no "bin-full" indicator.
Dec 28, 2010 | Royal Office Equipment & Supplies
I was shredding paper - less than 8 sheets - and I didn't realize the receptacle was full. The shredder jammed and reversing it does not help. How can I de-jam?
When you unplug the shredder and take the top off, pull any jammed sheet through. Empty the receptacle. Then try putting the top back on and plug in and test it.
Aug 21, 2009 | Compucessory CCS 60062 Shredder
Need a replacement parts
Try calling their customer service in the US at 800-945-4545.
Feb 01, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellowes PS60C-2 Shredder Logo
26 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
