Question about Hampton Bay 92650 Stand (Pedestal) Fan
Motor replacement Weather work pedestal fan not working. I opened up the motor, saw stator and rotor, greased up the rotor ends and applied WD40 on stator. I put it back together but the fan still doesn't work. Please help.
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Sorry. That's what happens when you buy a store brand.
Posted on May 17, 2013
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Pedestal fan motor
Go to this link and find the dealer local to you; http://hamptonbayinfo.com/Product.aspx?pid=9eb435cd-4f97-4074-bdf3-630f1efd7a83&cid=791075 They should be able to either supply parts or tell you where to get them. Hope this helps, sorry for the delay but there are more problems than experts available at the minute :)
Posted on Mar 22, 2007
ghappliances
  • 126 Answers
SOURCE: fan motor does not turn
FIRSTLY HOW MANY WIRES ARE COMING OUT THE FAN MOTOR AND WHAT COLOUR DO YOU GUYS USE AS LIVE AND NETURAL IN YOUR COUNTRY.
MOHAMED
Posted on Sep 19, 2008
  • 248 Answers
you may be able to get a replacement motor in your area,but it will most likely cost as much as a completley new fan.these type motors in my area usually run around 100.00
Posted on Oct 06, 2010
RE: Bionaire BSF1620RC Pedestal Fan - blades won't turn. I have had this fan for about 4 years - 2 of which the fan has been stored. It was well protected so I don't know why it isn't working. but the...
These run very small motors with low "starting torque" If the fan hasn't been run for a long time, its possible that it has jammed up or got tight from just sitting there. Being careful, turn on the fan and spin it in its usual direction by hand, it should start running. If you cannot spin by hand, it may have seized up which will require you to strip and lube the motor. If you manage to get the fan spinning , let it run on high fan speed for an hour or so, it should free up and then be OK again. A small spray of WD40, CRC or similar spray can lube on the fan shaft where it disappears into the motor may assist.
Feb 03, 2015 | Bionaire Dryers
How do I clean the gears that raise, lower, and elevate the blade on an older model Craftsman Table Saw. Is the housing completely sealed to prohibit cleaning?
I don't know without seeing it but you could use a shop vac on all the openings and see if you can spray WD40 but it will remove grease so then apply a spray grease.
Jan 07, 2015 | Craftsman Saws
Heater fan does not work when below freezing outside
There could be water entering the blower motor that is freezing and not letting the motor spin. You can remove the blower motor and inspect for water. If there is water in the motor... the source of the leak will have to be pinpointed.
Dec 06, 2012 | 1999 Ford Explorer
How to oil a standing Hunter fan
If the fan does not have 3-in-1 oil'r cap located near each end of fan, then lay fan down so blades are up. Then use WD40 with straw to spray on the turning shaft and let oil drip down for several hours.
You cannot over-oil a turning shaft, so plenty of WD40. Just be careful because air mist from WD40 is harmful to breathe and vapor is extremely flammable, so no smoking while spraying.
Sep 21, 2012 | Hunter (90121) Stand (Pedestal) Fan
Just purchased an AO Smith condenser fan motor, installed it but it runs counter clockwise, how do i reverse it to run clockwise?
Hi, this is very easy to do. On the back end of the motor you will see a pair of wires plugged in to each other. Kill the power and just unplug and reverse these wires. This will reverse the rotation of the condenser fan motor. If you have no wires, check for an arrow on the motor housing. It will only go one way if there is one, and you will need to take it back. 2 pair of wires...., just reverse them very easy. Tie or tape them away from the blade.
Mar 19, 2012 | Heating & Cooling
Have a 2001 Sienna with a right hand sliding door. It will not open all the way or close properly in foul weather this seems to be the only time it acts up. Can you Help? Mark.
Try cleaning and applying a light lubricating grease to track top & bottom. Old grease gets stiff in cold weather and is creating resistance. Do NOT use WD40, use a light lithium based grease available at any parts store.
Mar 25, 2011 | 2001 Toyota Sienna
Holmes "16 fan needs to be lubricated. Where do you add oil
No there is no way to lubricate the new cheap fans internally...they are made to run for a bit and then be thrown out...
I have found that by using a thin oil like WD-40 and then positioning the motor so that it runs back the shaft into the motor you can get it to work into the motor. I usually use WD-40 and then follow with a light motor or sewing machine oil. This seems to give a longer solution...
heatman101
May 05, 2010 | Holmes Products HASF1516 Stand (Pedestal)...
Pedestal fan motor
May 26, 2009 | Hampton Bay 92650 Stand (Pedestal) Fan
Not cooling
disconnect power ...remove lower back panel ...... remove fan and replace.... used appliance shops are a good place for free or cheap fans
I have done this many times on my rental properties
ed
Oct 20, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Hampton Bay 92650 Stand (Pedestal) Fan Logo
377 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
