Question about Cell Phones
Install guide i don't know installing procedure
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cell Phones Master
  • 102,366 Answers
Install what onto what?
Posted on May 09, 2013
How to enable bluetooth in bios setting in acer 4736Z?
HI...........................
Problem with the Mac Laptops How to enable bluetooth in bios setting in acer 4736Z?
SOLUTION NO 1:
Check your device manager first, if your Bluetooth driver not installed properly, then you have to installed it first. If you don't have that driver you can download it from internet. You have to specify the model no. of your laptop and Bluetooth after that you can download and install the driver and use your Bluetooth. If you find any difficulty in installing driver then there are web sites where you can find the whole procedure step by step.
SOLUTION NO: 2
I think you have installed a wrong driver or your driver has not been installed properly. You should check first in device manager for installed driver, if it is installed then you can see in a list below in that and if not then you have to install that first. You can download a Bluetooth driver for your machine from internet. You have to out your model no. of your laptop and you'll find it. After installing you can see the driver in device manager or it can also be seen in a icon near task bar.
SOLUTION NO: 3
Install the driver of your Bluetooth from a cd or download it from internet. After downloading install it in your system and it will work fine. If this does'nt work for you, then get an external Bluetooth it come with its own driver so you don't need to install it from internet. If you don't know the procedure of installation then follow the instruction in cd or online, it will help you in installation.
HOPE THIS SOLUTIONS IS HELPFUL TO YOU...................
GOOD LUCK.......................
Sep 24, 2011 | Computers & Internet
I need to figure out how to install a 2001 Hyundai Elantra
Since I don't know what you're trying to install, there's very little help I can provide except let you know you can Have a qualified Hyundai Service Technician do the work, or you can Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc.
Aug 30, 2011 | Hyundai Elantra Cars & Trucks
I downloaded iTunes, but don't know how to install
Hi denisepryor6...
You will go to where itunes was downloaded and double left click on the icon...that will start the wizard to guide you thru the installation.
Most downloads will go to "My Documents"
Please take time to rate me
Jul 30, 2011 | Computers & Internet
I just purchased a new camera. The fujiiflm XP Finepix XP20 series. The user guide is useless and so is the CD. Nowhere does it show you where to plug in the USB cable on the camera nor does it tell you...
I don't know what user guide you're looking at but this is a very comprehensive guide. The parts of the camera are on pg.2&3 showing clearly #18 is the usb connector on the camera. Pgs. 53-59 describe the transfer procedure and installing the necessary software.
Jul 29, 2011 | Fuji Cameras
I purchased a new Goodman AC/Heat inside and out side units, am getting ready to run the wiring to the sub panel, Not sure what wire to use from the main braker box to the sub box have found different...
http://www.encorewire.com/docs/amp%20voltage.pdf is a diagram of what size wire and type you need for different amperage. As you can see the 10/3 recommendation is good for a maximum of 30 amps in copper and 25 in aluminum.
I haven't found the CKL36AR36 installation guide, so I don't don't know which circuit breaker size you need to install. But it should be listed in your installation guide that you got with your unit. Make sure that you have the correct disconnect within 6 feet of the unit to meet code.
Jul 12, 2011 | Goodman CKL36AR36 Air Conditioner
Intall windows vista
Kindly mention the problem in detail?
Are you looking for the procedure to install Vista ?
If yes, you could follow the below guide :-
http://windows.microsoft.com/en-US/windows/help/install-reinstall-uninstall
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 15, 2011 | Computers & Internet
I need the user guide for my Vivicam 8340 digital camera, since I want to install an SD card on it but I don't know how to do it. Thank you, in advance!
The user guide is not available online as a download. However installing an SD card is usually pretty simple. On this camera, the SD card slot is on the bottom inside the compartment where the battery is housed. Simply slide the door open, and locate the slot for the memory card. The memory card should only go in one way, so don't try to force it. If it doesn't fit fairly easily try turning the card around. Remember: the gold pins on the card go into the camera!
May 05, 2011 | Cameras
I was told to reformat my computer. I don't know how. Can you help?
Actually, it's not recommended without know how to do it since it should be done by a professional or by an experienced engg/tech. Well, before you decide to format, you'll need a Windows cd, if you wish to install Windows xp, you'll need a Windows XP original CD or if you wish to install Windows Vista, you'll need a Windows Vista DVD, in the same way with Windows 7. Note: Formatting means wiping out everything from your computer, usually C drive so that you'll be able to install another copy of Windows, which means you'll first format the C drive and then install a new copy of Windows, without Windows being installed, you computer will never run, it's similar to a useless or dead machine. I don't mean only Windows, same conditions apply with Linux or Mac.
If you want to try yourself following the instructions, let me give you few links, but it's not a simple and short process, and I won't take the risk if you fail (this is why I'd mentioned that it's a job to be done by a pro). Here are few links from BlackViper.com regarding Installing Windows. Follow the link/s and follow the instructions, there might be several pages, so make sure you scroll down to the bottom of the page/s and click "Next Page" if you are done with the first/previous page. Before you begin, please read the full tutorial/s so that you will know what exactly you're going to do with your computer. If you can still boot up your computer, make sure all the files are moved from C drive to another partition or I would recommend backing up your computer's files.
1. Windows XP install guide.
2. Windows Vista install guide.
3. Windows 7 install guide.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 01, 2011 | Microsoft Computers & Internet
Need an installation and setup guide for tmc soho m4810.
you have to assign an ext to the phone.Press Program and extension button to assign it to an extension.
all phones have to have different assigned ext (obviously)...
To cancel stored extension(to change) Press program, press PAGE twice, press mute.
I need the users guide!!! have quite a few install and set up guides - I just need the users guide!!! need to change time and other things!!!
Please help...will trade...
Jun 30, 2009 | TMC M4810 NON-KSU Corded Telephone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
