Question about Zojirushi Kitchen Appliances - Others
Zojirushi bbccS15 I got this machine used. Its worked great except recently it went through the dough cycle (I only use dough cycle) and I came back to the machine and nothing had been mixed at all. I HEARD some turning, and the cycle completed, but no mixing. The next time I used it it worked fine, and then the last time I used it it did the same thing where it cycled through, made sounds, but nothing was mixed at all. Please tell me the most likely problem and what I need to do to fix it if you can, thanks.
SOURCE: makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Posted on Jan 03, 2009
JSEhandyman
  • 368 Answers
SOURCE: Zojirushi BBCC-X20 rubber gasket breakdown
Hi D Daniel,
I'd start by getting a new part. Gaskets can be made from a variety of materials - and different types of rubber, or silicon, will have different characteristics. The manufacturer should be able to provide this information to a concerned consumer.
I'd go to Zojirushi's Support page at (TinyURL'd for brevity)
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If these don't pan-out (no pun intended, I think), the next place I'd start hunting is eBay.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
SOURCE: need new blades for Zojirushi bbcc-x20 bread
http://www.thegourmetdepotco.com/store/store_partaccess.asp?manufacturer=33&category=-1&search=BBCC-X20
Posted on Apr 04, 2009
KMusselmann
  • 247 Answers
SOURCE: My Sunbeam breadmaker runs all cycles but doesnt mix.Breadpan is
Bread Machine Replacement Parts If you are having problems with your bread machine you may be able to fix it with replacement parts. That is if it is the paddles or the pan you are having problems with. If it is something within the bread machine that is not working properly then you probably won’t have a lot of luck finding these bread machine replacement parts.
Keep in mind the price of the bread machine replacement parts as well. If they are very expensive you will be better off just buying a new bread machine. But, if your bread machine was really expensive and is still in good shape and the replacement parts aren’t that much, then the replacement parts might be a better option for you.
Most bread machines work well for years without the need for replacement parts and many machines have warranties as well. But, if you are having problems then you will need to decide if replacement parts or a new machine are the right option for you. If you need replacement parts then call the manufacturer of your bread machine.
Posted on Apr 08, 2009
KMusselmann
  • 247 Answers
SOURCE: I need the dough mixing blade for my bread machine
You can get it at the following site
http://breadmakerguru.com/
Kurt
Pls rate the answer
Posted on Apr 10, 2009
Went thru a complete dough cycle, Turned the machine off. Cleaned the bucket, then went to start another batch. Nothing, no beeps, no lights. Is there a reset?
This happened to me also. What worked for me was to unplug the machine and wait at least an hour, then plug back in. It may reset for you. Good luck
May 08, 2015 | Cuisinart CBK-200 Bread Maker
I am just trying to figure out how to make dough. It is my moms machine and she is out of the country. Please help
Just put the ingredients in if you have a recipe and choose the Dough program and push start.
Aug 11, 2011 | Zojirushi BBCEC20WH Bread Machine
Crust is thick and hard, paddles tear large chunk from bottom of loaf when removed from pan.
unfortunately all bread machines leave the hole in the bottom where the paddle is. some machines leave a bigger hole than others, with the exception of the cuisinart cbk-200 which allows you to remove the dough, then remove the paddle, then reshape and replace the dough....One thing you can try to have a softer, lighter crust is to replace the water in your recipe with the same amount of milk. If the hole in the big hole in the loaf really bothers you I suppose you could remove the dough exactly at the end of the final knead, remove the paddle and replace the dough in the pan...I've never done it but I've certainly considered it! best wishes and happy breadmaking...
Nov 08, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Machine stuck during kneading cycle
Check here:
http://manualfox.com/link/westbend.htm
They can get you any West Bend manual. Just send them a request.
Apr 02, 2009 | West Bend 41089 Bread & Dough Maker
I have black spots in my bread dough
I get black smeary streaks in my dough too. I just bought a new machine because this happened in my old one. But, on about my 5th loaf in this new machine, I have little black spots and small smears. This is how my other machine started out and then the smears were thorughout the whole loaf after a month more.
Help, what is this!
Jan 07, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Dough does not rise
Make sure you are following the recipe very carefully. You have to have the proper type of four, and yeast. Make sure you are using flour that is called bread flour. This type of flour has higher glutent than cake flour. Cake flour would make a heavier bread.
As for the yeast, there is a special yeast for bread machines. Regular yeast would be too slow acting for most bread machines.
Jerry G.
Nov 08, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
My breadmaker model BBCC-V20 completes the entire cycle, however the dough does not rise at all! I've tried with brand new ingredients eggs bread flour and yeast. Tried 3 times - no success at all.
Hi ravimalini,
Something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the new yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
You might be able to get more product-specific assistance from Zojirushi.
Jon
Nov 07, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Bread machine
Hi spudguard,
If you're looking for OEM parts, I'd go to
As for fixing the black plastic base, you'd have to describe what kind of plastic it is, and whether or not you plan to DIY or have it done, is it subject to high temps, etc. For a lot of that stuff, it's easier to get new unless you're going to glue it up yourself, but you should know what you're doing or get help. I'll give you more advice if you give me more information.
Jon
Oct 28, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Hi D Daniel,
Jon
Mar 17, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Dense, heavy loaves
Hi nanearl,
(A personal aside - my personal experience with home-baked bread is that it tends to be a heavier product - - but that may be because the recipe gets experimented with, and whole grain flours tend to be used rather than bakers flour.)
It sounds like something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
Jon
Feb 16, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Kitchen Appliances - Others Logo
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
