Blue vertical line document scan adf email hp m3035 mfp
luis356
  • 53 Answers
SOURCE: vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Posted on Jun 02, 2009
SOURCE: vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Posted on Sep 03, 2009
sys_admin
  • 829 Answers
SOURCE: Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Posted on Jan 26, 2010
hansola
  • 279 Answers
SOURCE: How do i scan on HP LaserJet M3035 MFP from
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
Hope this helps.
Posted on Jun 07, 2010
  • 38 Answers
SOURCE: Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Posted on Jul 13, 2010
From computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Feb 13, 2016 | HP Office Equipment & Supplies
HP Laserjet m5035 blue line when colour scanning to email
Try checking for debris or other on the ADF itself and below on the prism. The ADF cover glass could be spotless, but if there is a speck on the prism itself, this could cause the actual prism to send a line while scanning.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
Laserjet m5035 line when colour scanning
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
It is copying black lines on the documents when it is sent through the top feeder but not if it is copied on the glass
The printers problem is that there is dirt or dust on the ADF glass. Lift the top cover as if you are going to copy using the flat bed glass. Look to the left of the large glass, you will see a thin glass strip. Clean it, damp lint free cloth. You should be back in business.
Sep 02, 2011 | HP LaserJet M3035 MFP Printer
HP M3035 ADF has two black plastic pieces that interact with the roller gear assembly. One black piece has a cutout that fits around the blue button that you press to release the roller gear assembly and...
Unfortunately for this model the ADF section isn't broken down into it's individual components,
the part numbers available for the ADF are as follows: (direct from the Service Manual)
Control Panel
CB414-60101
Cover, ADF
CB414-67902
ADF feed roller kit
CB414-67904
Input tray, ADF
CB414-67903
ADF assembly
CB414-67916
Scanner assembly (ADF assembly is not included)
CB414-67905
However your best bet would be to call around to all of your local printer repair shops in your area and asking them if they have any of these M3035's sitting around for spare parts.
Otherwise I could try to find a good picture of the ADF Feed roller kit and see if it contains the parts you're looking for.
Hope this helps! If so please don't forget to leave a positive review for me. :)
Jun 07, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
HP 3035 MFP keeps coming up with a "Jam in document feeder " error message. The offending material has been removed from the ADF and yet the error message will not go away. The device has...
The most common cause for this is a jammed paper sensor flag under the top cover of the ADF where the paper is fed. ( small black plastic protrusion )that should should be positioned at the front of its little slot. I think there are 2 sensors so check that they are functioning properly ( that they move from right to left & then spring back )
May 11, 2011 | HP LaserJet M3035 MFP Printer
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
Have a Phaser 6110 MFP. When I scan a page using the ADF I get 3 color lines running vertically down the image. If I don't use the ADF, the page scans without the lines. What could be causing this?
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Dec 04, 2009 | HP LaserJet 2840 Printer
62 people viewed this question
jasbo
jasbo
